1st March February 2012
Latest post 07-25-2010 7:04 AM by richtoy. 5 replies.
07-24-2010 6:04 PM
richtoy
- Joined on 09-20-2007
- Valkenburg, Netherlands
- Posts 184
MX5500 BM4500 options question
I want to use an MX5500 with a BM4500 and a pair of P45s in a bedroom.
The TV and BM will be connected via the their respective AUX sockets and the P45s connected to the BM4500.
If I set the BM4500 to option 2 (displays 2.5) and the MX5500 to option 0 with its speakers set to External then sound comes from the P45s connected to the BM4500 as expected but when I switch to TV I get the sound of the TV from the P45s but no picture.
If I set the BM4500 to option 0 (displays 0.5) and the MX5500 to option 2 then I must set its speakers to Internal to get any sound. When I press TV the BM does not come on. When I press radio then sound comes from then MX5500 and the BM4500 always mutes.
What are the proper option settings?
Is there a definative guide to the options? There are bits and pieces in a few user guides but an overall guide would be nice...
Richard
Some of my B&O: BV3/32, MX7000, MX5500, LX5500, MX4000, BM8000, BM6000, Overture, BL8000, BM6000 Quad, BM4400, BM3400, BG-CDX, BM3000, BM1001, BM1200, BM1600, BM1700, BM1500, BM1400, BM2400, BM2300, BM4500, BM4000, BVM70, BVS45-2, BVS60, BC7700, BM2200, BM1900, BG8002, BM1202, BVPenta, BVP45
Large48
- Joined on 06-24-2008
- London
- Posts 455
Re: MX5500 BM4500 options question
Doesn't the MX5500 have connections to allow the P45's to be directly connected to the TV?
Train Hard - Run Fast - Hit to Kill!!!
richtoy
- Posts 184
Yes it does but I thought the amplifier in the BM4500 is more powerful.
So I use A.OPT 0, V.OPT 2 and connect the speakers to the MX5500?
tournedos
- Joined on 12-08-2007
- Finland
- Posts 5,808
Yes, I believe the only "good" setup is having the speakers connected to the TV. The downer is that the amps in the MX aren't that great, and I wouldn't trust the quality of the audio routing circuitry that much either (so even active speakers wouldn't solve the whole problem)...
I once tried to setup my BS6500 (with passive Pentas) and MX6000 so that the TV sound would come automatically through the BS while audio functions would continue working normally. I never got it completely working - either the picture was missing or the TV turned needlessly on.
Vienna
- Joined on 08-15-2008
- make an educated guess
- Posts 712
richtoy:
I'm not sure, but I remember there has been a SW issue for early MX5500/BM4500 and similar setups beeing not capable for a "full" A/V Opt.Setup 0/2 (the two digit readout e.g 0.5 or 2.5 indicates that it might be the old SW version)
SW versions of both units would help.
richtoy
- Posts 184
BM4500 has version 1.6
MX5500 has version 2.2S
I read elsewhere on the forum that the BM4500 can be upgraded to version 2.2
Exactly what is the delta between 1.6 and 2.2?
Page 1 of 1 (6 items)
