Latest post 07-25-2010 7:04 AM by richtoy. 5 replies.
Page 1 of 1 (6 items)
  • 07-24-2010 6:04 PM
    • richtoy
    • Top 500 Contributor
    • Joined on 09-20-2007
    • Valkenburg, Netherlands
    • Posts 184
    • Gold Member
    MX5500 BM4500 options question
    I want to use an MX5500 with a BM4500 and a pair of P45s in a bedroom.
    The TV and BM will be connected via the their respective AUX sockets and the P45s connected to the BM4500.
    If I set the BM4500 to option 2 (displays 2.5) and the MX5500 to option 0  with its speakers set to External then sound comes from the P45s connected to the BM4500 as expected but when I switch to TV I get the sound of the TV from the P45s but no picture.
    If I set the BM4500 to option 0 (displays 0.5) and the MX5500 to option 2 then I must set its speakers to Internal to get any sound.  When I press TV the BM does not come on.  When I press radio then sound comes from then MX5500 and the BM4500 always mutes.
    What are the proper option settings?
    Is there a definative guide to the options?  There are bits and pieces in a few user guides but an overall guide would be nice...
    Richard
    Some of my B&O: BV3/32, MX7000, MX5500, LX5500, MX4000, BM8000, BM6000, Overture, BL8000, BM6000 Quad, BM4400, BM3400, BG-CDX, BM3000, BM1001, BM1200, BM1600, BM1700, BM1500, BM1400, BM2400, BM2300, BM4500, BM4000, BVM70, BVS45-2, BVS60, BC7700, BM2200, BM1900, BG8002, BM1202, BVPenta, BVP45
    Filed under: , ,
  • 07-25-2010 3:23 AM In reply to
    Re: MX5500 BM4500 options question
    Doesn't the MX5500 have connections to allow the P45's to be directly connected to the TV?
    Train Hard - Run Fast - Hit to Kill!!!
  • 07-25-2010 4:21 AM In reply to
    • richtoy
    • Posts 184
    • Gold Member
    Yes it does but I thought the amplifier in the BM4500 is more powerful.
    So I use A.OPT 0, V.OPT 2 and connect the speakers to the MX5500?
  • 07-25-2010 4:59 AM In reply to
    Yes, I believe the only "good" setup is having the speakers connected to the TV. The downer is that the amps in the MX aren't that great, and I wouldn't trust the quality of the audio routing circuitry that much either (so even active speakers wouldn't solve the whole problem)...
    I once tried to setup my BS6500 (with passive Pentas) and MX6000 so that the TV sound would come automatically through the BS while audio functions would continue working normally. I never got it completely working - either the picture was missing or the TV turned needlessly on.
    -mika
  • 07-25-2010 6:29 AM In reply to
    • Vienna
    • Top 100 Contributor
    • Joined on 08-15-2008
    • make an educated guess
    • Posts 712
    richtoy:
    I'm not sure, but I remember there has been a SW issue for early MX5500/BM4500
    and similar setups beeing not capable for a "full" A/V Opt.Setup 0/2
    (the two digit readout e.g 0.5 or 2.5 indicates that it might be the old SW version)
    SW versions of both units would help.
  • 07-25-2010 7:04 AM In reply to
    • richtoy
    • Posts 184
    • Gold Member
    BM4500 has version 1.6
    MX5500 has version 2.2S
    I read elsewhere on the forum that the BM4500 can be upgraded to version 2.2
    Exactly what is the delta between 1.6 and 2.2?
