Latest post 07-25-2010 3:20 AM by stotty1111. 3 replies.
Page 1 of 1 (4 items)
  • 07-23-2010 7:12 PM
    • mor
    • Top 500 Contributor
    • Joined on 04-19-2007
    • Cologne
    • Posts 104
    MX 6000 - How to change the sound system from UK to Cont. Europe (I to B/G)
    Hello,
    we're moving back from London go Germany and need to set the sound system back from "I" to ""B/G" ...
    Does someone know how to do this on a rather aged MX 6000 ???
    Appreciate any hints!!!
    MOR
  • 07-24-2010 3:52 AM In reply to
    • stotty1111
    • Top 75 Contributor
    • Joined on 12-16-2007
    • UK / France - Nth Worcestershire/Finistere
    • Posts 924
    • Gold Member
    Re: MX 6000 - How to change the sound system from UK to Cont. Europe (I to B/G)
    Think it should be in the Menu - tuning area - if a multi standard tuner is fitted then an option with I should scroll thro the other tuner options if only I is available the the tv was country specific!
    I recently moved an MX7000 to france and it had a multi standard tuner fitted which worked fine until June 8th when my area went digital - now use a cheapo Elap ultimo 2 box which has the advantage of a usb outlet to record to hdd - cost about 30€!
    salut
    Tony
    I always try to operate using/following the KISS principle --  Keep it simple stupid!
  • 07-24-2010 6:37 PM In reply to
    • richtoy
    • Joined on 09-20-2007
    • Valkenburg, Netherlands
    • Posts 184
    • Gold Member
    Bad news i'm afraid, there is no was to do this with the MX range of TVs.  In europe I think the MX range are either continental european (PAL B/G) or UK (PAL I) and it is a different tuner board between them.  I think the NICAM encoding is also different between the UK and the rest of europe.
    Some of my B&O: BV3/32, MX7000, MX5500, LX5500, MX4000, BM8000, BM6000, Overture, BL8000, BM6000 Quad, BM4400, BM3400, BG-CDX, BM3000, BM1001, BM1200, BM1600, BM1700, BM1500, BM1400, BM2400, BM2300, BM4500, BM4000, BVM70, BVS45-2, BVS60, BC7700, BM2200, BM1900, BG8002, BM1202, BVPenta, BVP45
  • 07-25-2010 3:20 AM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    I agree - with earlier tv's country specific however later tv's like mine has a multi tuner which covers  all  western european  counties - you may be lucky!
    Tony
