        1st March February 2012
	    Latest post 12-03-2010 9:34 AM by  Evan. 9 replies.
								        07-18-2010 11:52 PM
									        sodoi18
								                - Joined on 02-06-2010
								                - USA
								                - Posts 194
										    How good is this woofer and can I use this connected to beosound 4000.
What else would I need to have this work with my setup with a pair of beolab 4000.
Is it worth getting this used or should I consider a beolab 2 instead.
Do I need a ML MCL convertor?
									    Beovox RL 60.2, RL 6000, S45-2, CX 50, Cona, Beolink Passive, MCL2P, BM4500, Beosound 1, Beocenter 2500, Beolab 2500, Besound 4000, Beolab 4000, Beocom 6000, A8, Beosystem 1
									        j0hnbarker
								                - Joined on 04-16-2007
								                - LS28/GB
								                - Posts 2,002
										    The Cona is a passive sub. To be honest I can't see it working with your current setup. It was designed to boost the bass from smaller CX passive speakers, in a setup where the Beomaster has an internal amp to power it. The Cona's crossover then filters the higer frequencies out for the CXs, but it can be quite directional. I actually like the Cona a lot (it looks great too - there's one in MoMA) and use mine with a Beomaster 8000 and some Beovox Pentas, and the bass boost can be welcome in my large living space.
For you though, I'd get the Beolab 2 as it hook up perfectly to your current system :)
									        kallasr
								                - Joined on 04-19-2007
								                - Willich, NRW, Germany
								                - Posts 1,077
										    Or any other brand active hub (search this forum, for example velodyne, KEF etc.) and an adapter cable
Ralf
									    My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
									        wirralsimon
								                - Joined on 04-17-2007
								                - Birkenhead, UK
								                - Posts 1,253
										      j0hnbarker:
Isn't this just the sort of situation that the new Beolab 11 is designed for?  The Beolab 2  is probably overkill paired with a couple of Lab 4000's, esecially as Home Cinema hasn't been mentioned.
Simon
									        sodoi18
								                - USA
								                - Posts 194
										    Will some thing like this would be good.
If so what would be the best way to connect this to ouverture.
									        sodoi18
								                - USA
								                - Posts 194
										    How much is the beolab 11
									        Evan
								                - Joined on 12-15-2008
								                - Ohio | USA
								                - Posts 2,601
										      sodoi18:
Right around $3,000. Someone please correct me if I am wrong.
									        macsat
								                - Posts 40
Price in the US is around 2200 USD
        Page 1 of 1 (10 items)
