Latest post 12-03-2010 9:34 AM by Evan. 9 replies.
Page 1 of 1 (10 items)
  • 07-18-2010 11:52 PM
    Beovox cona
    How good is this woofer and can I use this connected to beosound 4000. What else would I need to have this work with my setup with a pair of beolab 4000. Is it worth getting this used or should I consider a beolab 2 instead. Do I need a ML MCL convertor? Thanks
    Beovox RL 60.2, RL 6000, S45-2, CX 50, Cona, Beolink Passive, MCL2P, BM4500, Beosound 1, Beocenter 2500, Beolab 2500, Besound 4000, Beolab 4000, Beocom 6000, A8, Beosystem 1
  • 07-19-2010 4:37 AM In reply to
    Re: Beovox cona
    The Cona is a passive sub. To be honest I can't see it working with your current setup. It was designed to boost the bass from smaller CX passive speakers, in a setup where the Beomaster has an internal amp to power it. The Cona's crossover then filters the higer frequencies out for the CXs, but it can be quite directional. I actually like the Cona a lot (it looks great too - there's one in MoMA) and use mine with a Beomaster 8000 and some Beovox Pentas, and the bass boost can be welcome in my large living space.
    For you though, I'd get the Beolab 2 as it hook up perfectly to your current system :)
  • 07-19-2010 5:11 AM In reply to
    • kallasr
    • Top 75 Contributor
    • Joined on 04-19-2007
    • Willich, NRW, Germany
    • Posts 1,077
    Re: Beovox cona
    Or any other brand active hub (search this forum, for example velodyne, KEF etc.) and an adapter cable
    Ralf
    My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
  • 07-19-2010 5:44 AM In reply to
    Re: Beovox cona
    j0hnbarker:
    Isn't this just the sort of situation that the new Beolab 11 is designed for?  The Beolab 2  is probably overkill paired with a couple of Lab 4000's, esecially as Home Cinema hasn't been mentioned.
    Simon
  • 07-19-2010 2:56 PM In reply to
    Re: Beovox cona
    Will some thing like this would be good.
    If so what would be the best way to connect this to ouverture.
  • 07-19-2010 10:14 PM In reply to
    • Evan
    • Top 25 Contributor
    • Joined on 12-15-2008
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Re: Beovox cona
    My setup consists of 2 conas. This, in my opinion, sounds much better than running both channels through the same cona, as both channels will kind of fight over the single driver. Great speakers in an appropriate setup.
    Getting back to the original concern, I think active is the way to go here.
    Evan
  • 07-19-2010 11:45 PM In reply to
    Re: Beovox cona
    How much is the beolab 11
  • 07-20-2010 12:26 AM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Re: Beovox cona
    sodoi18:
    Right around $3,000. Someone please correct me if I am wrong.
    Evan
  • 12-03-2010 4:56 AM In reply to
    Re: Beovox cona
    Price in the US is around 2200 USD
  • 12-03-2010 9:34 AM In reply to
    • Evan
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Re: Beovox cona
    Do you have the current BeoLab 2 price for comparison?
    Evan
