1st March February 2012
Latest post 07-18-2010 5:24 AM by Vienna. 15 replies.
07-17-2010 11:02 AM
Pauldeclercq
- Joined on 07-17-2010
- Posts 5
Clueless B&O virgin, how to connect BEOLAB 4500 speakers?
Hi there,
HELP
I have recently moved into a new appartment, on the wall are 4 BEOLAB 4500 active speakers, they are beautifull, there is however nothing else.
The cables to the speakers run in the walls to a central point.
I do not own a TV and do not intend to either. What do I need to connect these fantastic speakers to my music found on my MAC book Pro/IPOD.
Do I need a PreAmp?
I have aquired a beo4 remote.
If you could advise me, I would be most appreciative.
Thank you,
Paul.
KingOfSnake
- Joined on 02-07-2008
- Posts 359
Re: Clueless B&O virgin, how to connect BEOLAB 4500 speakers?
Paul, suggest you go for any single CD based stereo - 2300, 2500, Ouverture, 3000 or 3200 and use the AUX input to connect your equipment to from a 3.5mm jack. These stereos all support Powerlink outputs for your LAB4500's.
Pauldeclercq
- Posts 5
Thanks, I thought something like that would be required.
Paul.
Vienna
- Joined on 08-15-2008
- make an educated guess
- Posts 712
Since the late 80's PowerLink is beeing used as B&O standard connecton to connect active speakers like the BLb 4500 to B&O Audio and TVs.
This gives you freedom of choice to go for new equipment e.g. BeoSound 4 or a variety of pre-owned audio and/or TV equipment.
PS - wish I did not sell mine ...
Vienna
- Posts 712
Yes!
Be aware that the Ouverture was introduced mid 90's - so it possibly has beeing used for 15 years and might need some service ...
kallasr
- Joined on 04-19-2007
- Willich, NRW, Germany
- Posts 1,077
For sure this one is working fine...
Ralf
My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD, Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
kallasr
- Posts 1,077
.... it is my wife's auction
Ralf
Large48
- Joined on 06-24-2008
- London
- Posts 455
Paul, it's easy you just take them all off the walls and sell them to me....
Train Hard - Run Fast - Hit to Kill!!!
Vienna
- Posts 712
Large48:
... or to me....
Ralf
*g* ... when Ralf is (still) trusting his wife - the rest of the (beo)world also should ... *g*
Pauldeclercq
- Posts 5
Hi Ralf,
What does your wife charge to send them to Begium(antwerp 2020) or London(W11 1TQ).
I can only assume that it works properly :)
cheers,
Paul.
kallasr
- Posts 1,077
Hello Paul,
sure it works! See the auction for details, we answered your question there as well.
It is 29,90 Euro via Hermes (insured).
Ralf + Simone
Carolpa
- Posts 440
Pauldeclercq:
First the type of cables coming from the BL4500 has to be determined! Are the PowerLink (you got 2 DIN plugs), are they SpeakerLink plugs or are they line connectors
Depending of the type you can or have to choose a system. For example for the Ouverture it is necessary to have Powerlink cables.
Is it easy to reinstall new speaker cables?
Vienna
- Posts 712
Carolpa:
Pauldeclercq:
Carolpa is absolutely right, none of us asked about the cable type being installed.
You can check this easily:
- PowerLink - DIN 8pin
- SpeakerLink - DIN 4pin (3 pin + 1 spade)
- Line - RCA/Cinch concentrical (1 ring-shaped + 1 central pin)
Pauldeclercq
- Posts 5
The cables are powerlink Cables.
Vienna
- Posts 712
Pauldeclercq:
BINGO !
PL will give you a rich variety of B&O audio/video equipment that can be used ...
e.g. an Ouverture
Page 1 of 1 (16 items)
