Latest post 07-18-2010 5:24 AM by Vienna. 15 replies.
Page 1 of 1 (16 items)
  • 07-17-2010 11:02 AM
    Clueless B&O virgin, how to connect BEOLAB 4500 speakers?
    Hi there,
    HELP
    I have recently moved into a new appartment, on the wall are 4 BEOLAB 4500 active speakers, they are beautifull, there is however nothing else.
    The cables to the speakers run in the walls to a central point.
    I do not own a TV and do not intend to either. What do I need to connect these fantastic speakers to my music found on my MAC book Pro/IPOD.
    Do I need a PreAmp?
    I have aquired a beo4 remote.
    If you could advise me, I would be most appreciative.
    Thank you,
    Paul.
  • 07-17-2010 11:05 AM In reply to
    Re: Clueless B&O virgin, how to connect BEOLAB 4500 speakers?
    Paul, suggest you go for any single CD based stereo - 2300, 2500, Ouverture, 3000 or 3200 and use the AUX input to connect your equipment to from a 3.5mm jack.  These stereos all support Powerlink outputs for your LAB4500's.
  • 07-17-2010 11:54 AM In reply to
    Thanks, I thought something like that would be required.
    Paul.
  • 07-17-2010 12:23 PM In reply to
  • 07-17-2010 12:26 PM In reply to
    • Vienna
    • Top 100 Contributor
    • Joined on 08-15-2008
    • make an educated guess
    • Posts 712
    Since the late 80's PowerLink is beeing used as B&O standard connecton to connect active speakers
    like the BLb 4500 to B&O Audio and TVs.
    This gives you freedom of choice to go for new equipment e.g. BeoSound 4 or a variety of pre-owned
    audio and/or TV equipment.
    PS - wish I did not sell mine ...
  • 07-17-2010 12:32 PM In reply to
    • Vienna
    • Posts 712
    Yes!
    Be aware that the Ouverture was introduced mid 90's
    - so it possibly has beeing used for 15 years and might
    need some service ...
  • 07-17-2010 1:38 PM In reply to
    • kallasr
    • Top 75 Contributor
    • Joined on 04-19-2007
    • Willich, NRW, Germany
    • Posts 1,077
    For sure this one is working fine...
    Ralf
    My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
  • 07-17-2010 1:41 PM In reply to
    • kallasr
    • Posts 1,077
    .... it is my wife's auction Wink
    Ralf
  • 07-17-2010 1:51 PM In reply to
    Paul, it's easy you just take them all off the walls and sell them to me....
    Big Smile
    Train Hard - Run Fast - Hit to Kill!!!
  • 07-17-2010 2:38 PM In reply to
    • Vienna
    • Posts 712
    Large48:
    Big Smile
    ... or  Whistle  to me....
    Ralf
    *g*  ... when Ralf is (still) trusting his wife - the rest of the (beo)world also should ... *g*
  • 07-17-2010 3:00 PM In reply to
    Hi Ralf,
    What does your wife charge to send them to Begium(antwerp 2020) or London(W11 1TQ).
    I can only assume that it works properly :)
    cheers,
    Paul.
  • 07-17-2010 4:31 PM In reply to
    • kallasr
    • Posts 1,077
    Hello Paul,
    sure it works! See the auction for details, we answered your question there as well.
    It is 29,90 Euro via Hermes (insured).
    Ralf + Simone
  • 07-18-2010 1:21 AM In reply to
    Pauldeclercq:
    First the type of cables coming from the BL4500 has to be determined! Are the PowerLink (you got 2 DIN plugs), are they SpeakerLink plugs or are they line connectors
    Depending of the type  you can or have to choose a system. For example for the Ouverture it is necessary to have Powerlink cables.
    Is it easy to reinstall new speaker cables?
  • 07-18-2010 1:58 AM In reply to
    • Vienna
    • Posts 712
    Carolpa:
    Pauldeclercq:
    Carolpa is absolutely right, none of us asked about the cable type being installed.
    You can check this easily:
    - PowerLink - DIN 8pin
    - SpeakerLink - DIN 4pin (3 pin + 1 spade)
    - Line - RCA/Cinch concentrical (1 ring-shaped + 1 central pin)
  • 07-18-2010 3:15 AM In reply to
    The cables are powerlink Cables.
  • 07-18-2010 5:24 AM In reply to
    • Vienna
    • Posts 712
    Pauldeclercq:
    BINGO !
    PL will give you a rich variety of B&O audio/video equipment that can be used ...
    e.g. an Ouverture Yes -  thumbs up
