1st March February 2012
Latest post 07-18-2010 6:47 PM by Seanie_230. 21 replies.
07-16-2010 4:04 AM
Seanie_230
- Joined on 04-20-2007
- Milton Keynes, England
- Posts 962
Hello All
I am finally swapping out my BV7 MK3 for a Mark 4 next week.
i cannot wait as the panning on the MK3 has annoyed me for ages.
I was going to get a MK5 but im happy to sit one model behind the latest one.
The screen spec says 100/120Hz, will this be 120Hz on the external bluray player???
Beovision 7 MKIV (Blu Ray) Beolab 9 Beolab 6000 Beo 4 Beocenter 9300 Apple TV SKY HD Optoma HD65 Projector Lintronic TT455-RT-238 Beovision 3 MKII
quader
- Joined on 08-03-2007
- West Yorkshire, UK
- Posts 89
What is panning ?
I am looking to get a BV7 40 mk3 at the moment
Seanie_230
- Posts 962
Hi there
Panning i woudl describe as the image juddering when the image is fast moving.
Funny thing is my Partner never even noticed it but i did, more so when i had the cinema output on rather than on the main tv screen.
The MK3 is a absolutly lovely TV but i have an addiction that i like to upgrade and keep moving with the times.
I would reccomend you watch some of your fav programs on a MK3 so you can judge for yourself.
If you get a MK3 make sure the software is updated as the early software crashed all the time and the newer software has nice black menu's and you can disable internal components like tv and dvd so you can use them for external sourses.
Chris
- Joined on 03-19-2010
- Corbridge, UK
- Posts 353
I was told that the mk5 would not be a radical LED LCD developement, but a natural progression to a 200hz panel!
Good luck and i hope you enjoy it.
A Beovision 10-40 in black and red fret on order, Beo4, Beo6, many A8's, a pair of white and yellow Form 2's, Beocom 4, 28 inch Avant RF DVD, Apple TV and a wife that loves this stuff as much as i do!
Seanie_230
- Posts 962
Yeah the MK4 is 100/120Hz and the MK5 is 200Hz.
i dont know why the MK4 shows as 100 and 120Hz can anyone shed some light on this.
moxxey
- Joined on 04-14-2007
- South West, UK
- Posts 2,360
Seanie_230:
I didn't see any difference between my MKIII and MKIV in regards to panning. The MKIII issues were fixed in sw and they are the same as the MKIV.
Personally, I couldn't recommend a MKIII to MKIV upgrade. The differences don't justify the expense. I'd wait for the MKVI which surely should be LED based. That will offer a bigger jump.
tournedos
- Joined on 12-08-2007
- Finland
- Posts 5,808
Panning = the act of rotating a camera horizontally
Just so
that you know
Anyway image movement is a fundamental problem
in digital video processing, especially when the frame rate or
interlacing is changed (as with most flat panels). There can be big
differences between implementations, but no, I don't know anything
specific about these Beovisions.
Puncher
- Joined on 03-27-2007
- Nr. Durham, NE England.
- Posts 9,588
TV refresh rates are linked to the ac line frequency. IN CRT days they were 50Hz in Europe (PAL/SECAM) and 60Hz in the US (NTSC). Toward the end of CRT we saw 100Hz models to minimise flicker, where an "intermediate" frame was generated within the TV (the signal was still 50HZ refresh).
Model flat panels do much the same by generating more intermediate frames by DSP, to minimise motion blur, although the refresh rate is still a multiple on the line freqency. In Europe panels will refresh at 100Hz or 200Hz whereas in the US they same panel will refresh at 120Hz or 240Hz.
Seanie_230
- Posts 962
yeah i would love to wait for the MKVI but the jump from MK3 would be to expensive for me so i will jump from 3 to 4 then 4 to 5 then five to six and so on.
I like to keep up to date with the current technology as best as possible without needing to break the bank every year.
nguyenvanbo
- Joined on 04-13-2010
- Posts 7
Seanie
As much as I admire B & O it's not the technology that determines the purchase but their looks and how they will look in 5 years or more time.
Many of the B & O products are timeless with so many companies trying to emulate the style.
If you want technology, buy Sony or Samsung etc. You can replace them every year and still spend less than buying a Beovision 7 mkIV or mkV etc.
We all know B&O waits for technologies to be tried & tested. It will never be cutting edge technology but the designs they are installed will look gorgeous and remain so however dated the technology.
I can attest this with the humble Beovision3-32 on it's motorised stand. It suffers from panning, annoying but rare. The world cup was more than watchable on it.
Not that you need to from your list, but I would spend the money on Beolab 9s. They look great and will not date. Enjoy your purchase but remember it will never be cutting edge however its design will always be outstanding.
Nguyen
Seanie_230:
Flappo
- Joined on 05-22-2010
- Posts 168
they used to be cutting edge , look at the beogram 4k and co inventing dolby hx pro
i miss the old days
moxxey
- South West, UK
- Posts 2,360
Seanie_230:
What new technology? There's almost nothing new in the MKIV apart from a 100Hz screen! Plus SD on the MKIV was worse than the MKIII - I deifinitely noticed a difference.
Even if the upgrade was £2000, that's still a far amount to pay each year for a relatively minor upgrade. It's the same TV ;) For example, what's significantly new in the MKV apart from a jump in panel Hz?
Seanie_230
- Posts 962
Yeah the Beolab 9's would be lovely but i will need to do a home test first to see how i get on with the sound from them. The TV upgrade is more of a swap with a pre owned company so its no where near £2000 and i dont mind upgrading every year or two as the way i look at it
if i get the mk4 this year then my tv is worth x pounds, next year it will be worth less so the difference will increase so this way it keeps the price gap closer
Chris
- Corbridge, UK
- Posts 353
Has anyone tried buying a 7-40 and then upgrading it by just changing the screen?. IE the stand and say the beolab2 speaker remained, and a new screen fitted.
Seanie_230
- Posts 962
This is what i do each time i change my TV
I keep my stand and 7.4 and just change the panel each time.
moxxey
- South West, UK
- Posts 2,360
chris:
That's exactly what we do! Why would you replace the stand with the same stand? :)
moxxey
- South West, UK
- Posts 2,360
Seanie_230: The TV upgrade is more of a swap with a pre owned company....
Be careful though - I've had 3 x MKIV's so far and the first two (the early) editions alway crashed with a Sky HD box. This current one is from Jan 2010 and has been fine. This version has an updated panel, too, compared to the first MKIV.
nguyenvanbo
- Posts 7
I'm intrigued in this upgrading, how do get to find the screens only without shelling out for the stand & speaker. I'm also assuming you nanage to keep the beosystem 3 chassis?
Nguyen
Seanie_230
- Posts 962
the beosystem3 is built into the screen / panel
most of the pre owned companys will sell you a screen only
lifestyle av at the top of the forum page
www.morethanav.co.uk
www.iconic-av.co.uk
all of these will sell just a screen and even maybe PX your current screen
vikinger
- Joined on 04-16-2008
- Vestri Kirkjubyr, UK
- Posts 2,839
chris:
Judging by the number of screen only BV7's available from Lee at Lifestyle, that's exactly what owners are doing.
Graham
I used to be indecisive, now I'm not so sure. [W C Fields]
moxxey
- South West, UK
- Posts 2,360
Seanie_230:
most of the pre owned companys will sell you a screen only..
And any B&O dealer. Look at a dealers pricing and the BV7-40 is listed as a screen. All the stands/speakers are priced separately. It's always been that way.
Remember when you get a panel from your dealer you always receive the latest panel - B&O are always updating the panels through the lifespan of the model. For example, there was a marked improvement between my first BV7-40 MKIV panel in May 2009 and my third (and current) panel from January 2010. Was brighter and much sharper.
Seanie_230
- Posts 962
Yeah of course i forgot about dealers.
I found that the pre owned companies offer you more money for your panel that the main dealers but that could be location dependant.
If they can resell your screen quickly then the might have you a good offer
Page 1 of 1 (22 items)
