Hi Chris,
Thanks for responding.
I do own the Beomaster 5500 receiver.
When I ran the master control link (MCL) cable (20 years ago) I daisy chained it to a "central closet" where I then ran additional cables to the rest of the rooms.
(From the 5500 master location...I ran an MCL cable to "power" an adjoining room (kitchen-presently not connected)..dead ends there. I ran a second MCL cable (connects to the 5500) to a bathroom...daisy chain to a bedroom and then run downstairs to a bathroom...where I have MCL cables that run to the last three rooms).
I presently run the speakers in the same room as the 5500, and three additional rooms via the master link connection. I was planning to add speakers in an additional room...realizing that as the 4th link this would be the last room I could "link" to the system. I have run the MCL wire to three additional rooms that I was hoping to add over time.
I should have purchased the MCL 2E years ago...and I know they no longer make it.
When I built this house...it was constructed as a "super insulated" home (polyurethane foam insulation...very tough to "fish" wires). It also has no attic access (I could cut a hole in the ceiling to create...but would prefer not to).
So I am "worried" that if some of the options include running the latest version of the MCL cable...that may be an "impossible" task.
Your suggestions would be greatly appreciated.
Best Regards,
Bill
