Latest post 08-21-2010 8:08 AM by whayhurs. 6 replies.
Page 1 of 1 (7 items)
  • 07-14-2010 6:25 PM
    MCL 2E
    I own a very old system...5500.  I should have bought an MCL 2E link expander years ago (for the adding of future links) and I did not and i know the accessory is no longer manufactured.
    Would anyone know if and where i might be able to purchase an MCL 2E??
    Thanks,
    Bill Hayhurst
  • 07-15-2010 4:02 PM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Re: MCL 2E
    Hi Bill - welcome to Beoworld. Smile
    What are you wanting to connect to your sysytem? I'm assuming you have the Beomaster 5500, if so there may be other options.
    Chris.
  • 08-08-2010 8:11 PM In reply to
    Re: MCL 2E
    Hi Chris,
    Thanks for responding.
    I do own the Beomaster 5500 receiver.
    When I ran the master control link (MCL) cable (20 years ago) I daisy chained it to a "central closet" where I then ran additional cables to the rest of the rooms.
    (From the 5500 master location...I ran an MCL cable to "power" an adjoining room (kitchen-presently not connected)..dead ends there. I ran a second MCL cable (connects to the 5500) to a bathroom...daisy chain to a bedroom and then run downstairs to a bathroom...where I have MCL cables that run to the last three rooms).
    I presently run the speakers in the same room as the 5500, and three additional rooms via the master link connection.  I was planning to add speakers in an additional room...realizing that as the 4th link this would be the last room I could "link" to the system.  I have run the MCL wire to three additional rooms that I was hoping to add over time.
    I should have purchased the MCL 2E years ago...and I know they no longer make it.
    When I built this house...it was constructed as a "super insulated" home (polyurethane foam insulation...very tough to "fish" wires).  It also has no attic access (I could cut a hole in the ceiling to create...but would prefer not to).
    So I am "worried" that if some of the options include running the latest version of the MCL cable...that may be an "impossible" task.
    Your suggestions would be greatly appreciated.
    Best Regards,
    Bill
  • 08-09-2010 8:53 AM In reply to
    Re: MCL 2E
    I got a MCL 2E that I'm not using but I might sometime in the future so I'm keeping it.
    It was on US ebay and since I'm located in Denmark I got the power supply for US voltage if you need it.
  • 08-19-2010 10:05 PM In reply to
    • papichullo
    • Not Ranked
    • Joined on 04-17-2007
    • Pittsburgh USA
    • Posts 8
    I have three MCL2AV boxes without any eyes if you would like them I was just about to put them on ebay.
    MX5000,VX5500,MX5500,AV7000,Ouverture,BL4000,BL4,BS3300, RL45,Earset1,2,Beocom5000,5000 AV,6000
  • 08-19-2010 10:11 PM In reply to
    • papichullo
    • Not Ranked
    • Pittsburgh USA
    • Posts 8
    Re: MCL 2E
    I think there was also a 2E  and a Masterlink converter and with a few more MCL2AV's in storage. I will have to look. I am trying to clear all the extra  B&o out.  These are free if you are in the US.  I have no use for them and would rather see a fellow Beoworlder smile than wonder if they overpaid.
  • 08-21-2010 8:08 AM In reply to
    Re: MCL 2E
    Hi Papichullo,
    My name is Bill Hayhurst and I do live in the US.  If you are going to dispose of these items (especially the 2E) I would be very grateful to receive them.
    Please advise what info you need from me.
    Thanks very much.
    Best Regards,
    Bill
