Latest post 07-12-2010 4:49 PM by DoubleU. 6 replies.
Page 1 of 1 (7 items)
  • 07-12-2010 10:46 AM
    • dueno
    • Top 500 Contributor
    • Joined on 04-29-2007
    • bordeaux
    • Posts 147
    MX8000 and beo4 mark IV
    is there an update for beovision MX 8000 to be compatible with the beo4 type 1617?
    never explain never complain
  • 07-12-2010 1:32 PM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Re: MX8000 and beo4 mark IV
    Compatible in what way? It will still use the same I.R. codes.
    CraigSmile
  • 07-12-2010 2:53 PM In reply to
    • dueno
    • bordeaux
    • Posts 147
    with the menu pad
  • 07-12-2010 3:04 PM In reply to
    • Vienna
    • Top 100 Contributor
    • Joined on 08-15-2008
    • make an educated guess
    • Posts 712
    dueno:
    ?? Type 1617 ??
    "Standard" - Type 162x  (1995 - 2010)
    "Navigation button" - Type 1710 (2010 - ??)   *)
    Special version "Cinema" - Type 1626
    Special version "DTV+V.AUX button" - Order# 8053529 (2009 - ??)
    *) if set to "Mode 2" type 1710 will work like Beo4 type 162x
  • 07-12-2010 3:55 PM In reply to
    • dueno
    • bordeaux
    • Posts 147
    sorry!!!
    it is type 1710 and the compatibility with navigation button
  • 07-12-2010 4:34 PM In reply to
    • Vienna
    • Posts 712
    dueno:
    sorry!!!
    Don't believe that there will be an update for any of the older TV's !
    They made it the opposite way around - in "Setup Mode 2" the "Nav. Button" is
    disabled to be backward compatible ...
    If you don't use analog "TV" anymore the "DTV" / "V.Aux" / "V.Mem" Beo4  remote
    might be an even better alternative for the "digital age"
    Price should be the same as for a standard Beo4.
    Picture shows Beo4 "Digital Age" - DTV / V.Aux / V.Mem (B&O Order Number 8053529)
  • 07-12-2010 4:49 PM In reply to
    The picture above is not the new Beo4 (type 1710)
    edit: My bad, I misread your post!
