dueno:
sorry!!!
it is type 1710 and the compatibility with navigation button
Don't believe that there will be an update for any of the older TV's !
They made it the opposite way around - in "Setup Mode 2" the "Nav. Button" is
disabled to be backward compatible ...
If you don't use analog "TV" anymore the "DTV" / "V.Aux" / "V.Mem" Beo4 remote
might be an even better alternative for the "digital age"
Price should be the same as for a standard Beo4.
Picture shows Beo4 "Digital Age" - DTV / V.Aux / V.Mem (B&O Order Number 8053529)
