This is just getting so messy....
I just thought (as usual fooled by just assuming beo is the easy way) that a bv4 and a "previously expensive and advanced" beosystem 2 or 1 at least with dvi in some end would give me some kind of interaction with the new world compared to my old avant 28". But it seems harder than ever. When phoning a lot of shops they have all almost forgot everything about the bs2/bs1 and bs3 is the only way to get compatibility with todays 3rd party products.
Various info from various shops which sells beosystem: yes this bs2/2 has dvi, but the box is not hd-ready, that thing will cost you 500 Euros
This bs1/2box has only vga but it is still hd and very good but I dont know if it can actually output it to the screen
This bs1/2box has dvi but it does not have the correct software to tell your screen that it has dvi so you cant watch dvi
this bs1/2 box dont have dvi, but it is very expandable.... oh wait, you cannot expand it with hd, since it is hd-ready but not hd so it is not hd and cannot be hd.... uhhhhh
And MK2 is not hd, MK3 is hd ready, and "maybe upgradable" to this and that and "I dont know, I have to get back to you"
My god I have to quit my job just to figure this out....
How come it costs 500 euros to get this old "not-so-fancy-anymore" box to be hd-ready (in this FULL-HD world) ? It is not like I am buying myself a place beside current mainstream-tv-owners, I will just barely be running behind the bus....
