Latest post 07-08-2010 9:31 AM by quader. 10 replies.
Page 1 of 1 (11 items)
  • 06-25-2010 11:46 AM
    • quader
    • Top 500 Contributor
    • Joined on 08-03-2007
    • West Yorkshire, UK
    • Posts 89
    • Gold Member
    bv7 32 MK2 TRADING UP
    Has anyone traded up from BV7 Mk2 to BV7 40 MK?
    if so is it recommended and how what was the cost  or do B&O owners prefer the BV7 32
    Help and advice would be appreciated
  • 06-25-2010 12:26 PM In reply to
    Re: bv7 32 MK2 TRADING UP
    Its quite surprising how comfortable viewing is on a BV7 40. I had a 32" and upgraded to a 40" and love it.if you are upgrading, make sure you get the new 200HZ one released resently. I have a MK3 and the MK5 is superb.
    Cost depends on which MK you go for.
    Hope this helps.
  • 06-25-2010 12:29 PM In reply to
    • quader
    • Posts 89
    • Gold Member
    what are the cost for mk3 and 5 and what made you change
  • 06-26-2010 12:39 PM In reply to
    • quader
    • Posts 89
    • Gold Member
    come on beoworld users your suggestions and advice would be appreciated
  • 06-27-2010 8:35 AM In reply to
    • Dave
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Brisbane, Australia
    • Posts 2,328
    You give an inch...
  • 06-27-2010 6:12 PM In reply to
    Hi
    I upgraded from 6-26 to 7-40, couldnt be more happy with it. I have the MK3, with dvd. The DVD-player is very good, and the pictureprosessor in the integrated BS3 is flawless! I have a friend who has 7-32, and I must say, you cant compare them! If you can afford it, you should trade it, and try to get a mk3 to a good price. Mine is connected to ps3 with HDMI and the re-bl module. I can control everything on it (not gaming) with the Beo4. You can buy a bracket for the PS3 slim from STB-brackets, then you cant see ut from front. This way it is very easy to change blue-ray-discs. Picture with blueray is fantastisc, its almost like looking through a window! With PS3 you also have the opportunity to have a music-library, surf the web with the Beo4 (diffucult but works), and a great function to present your pictures. So again, if you got the money, go for it, and also buy a PS3.
  • 06-28-2010 2:53 AM In reply to
    • moxxey
    • Top 25 Contributor
    • Joined on 04-14-2007
    • South West, UK
    • Posts 2,360
    quader:
    Not sure what advice you are seeking? The primary difference between the 32 and 40 is the size of the screen, clearly. After I upgraded the 32 looked tiny in comparison. Movies are far better on the 40.
    The only downside is that standard definition TV is slightly more pixelated on the 40 as it as to be stretched to take advantage of the 1080P screen. I definitely noticed a difference there.
  • 06-29-2010 6:32 AM In reply to
    • quader
    • Posts 89
    • Gold Member
    i am not sure about the chasis and connections options at the back also the picture quality is it the same ?
  • 07-06-2010 12:23 PM In reply to
    • quader
    • Posts 89
    • Gold Member
    I did not realise the MK5 was around £11k
    is it better to get second life MK3 ?
  • 07-06-2010 12:57 PM In reply to
    • 9 LEE
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Moderator - UK
    • Posts 5,223
    quader:
    It depends entirely on your budget !!
    If you can afford a Mk5, it's obviously the better choice - and better TV.  If you can only afford to spend enough for a used Mk3, then i'm sure you won't be disappointed at all - the Mk3 is lovely!
    Lee
  • 07-08-2010 9:31 AM In reply to
    • quader
    • Posts 89
    • Gold Member
    thanks Lee, I am just waiting for my dealer to get hold of a Mk3,
    I currently have Beolabs 8000 and 4000 and currently thinking about a second centre speaker and rears any suggestions would be grateful.
    This is for the projector setup in the same room.
