Hi
I upgraded from 6-26 to 7-40, couldnt be more happy with it. I have the MK3, with dvd. The DVD-player is very good, and the pictureprosessor in the integrated BS3 is flawless! I have a friend who has 7-32, and I must say, you cant compare them! If you can afford it, you should trade it, and try to get a mk3 to a good price. Mine is connected to ps3 with HDMI and the re-bl module. I can control everything on it (not gaming) with the Beo4. You can buy a bracket for the PS3 slim from STB-brackets, then you cant see ut from front. This way it is very easy to change blue-ray-discs. Picture with blueray is fantastisc, its almost like looking through a window! With PS3 you also have the opportunity to have a music-library, surf the web with the Beo4 (diffucult but works), and a great function to present your pictures. So again, if you got the money, go for it, and also buy a PS3.
