Hi Martin, thank you for the instruction, it was very easy to do, but there is another problem. how can I remove the lamps. just pull or turn in any direction. they seemed to fit very strengh in place. I dont want to break or damage anything.
You wrote you have suitable lamps for sale. I am from Austria, where are you from?
