Latest post 06-20-2010 5:44 PM by Dillen. 4 replies.
Page 1 of 1 (5 items)
  • 06-19-2010 7:05 PM
    • mantra
    • Not Ranked
    • Joined on 06-19-2010
    • Posts 5
    beocenter 2100 - need help - how to replace the illumination
    hi there, does anybody know how to remove the frontplate on the right side of the Beocenter 2100 . I need to replace the lamps that illuminate the scale. Has anybody a step by step guide or a manual ? thanks
  • 06-20-2010 3:11 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: beocenter 2100 - need help - how to replace the illumination
    Welcome to Beoworld !
    Pull off the volume knob.
    Using a suitable tool, screwdriver or similar, press in the little tab on the left side
    of the dial cover (Blue arrow), while pushing the dial cover forward (Red arrow).
    Take off the clear dial by releasing the two small claws at its front edge.
    The lamps are soldered in.
    They are odd specs but I have suitable lamps if you need.
  • 06-20-2010 12:59 PM In reply to
    • mantra
    • Not Ranked
    • Posts 5
    Re: beocenter 2100 - how to replace the illumination
    Hi Martin, thank you for the instruction, it was very easy to do, but there is another problem. how can I remove the lamps. just pull or turn in any direction. they seemed to fit very strengh in place. I dont want to break or damage anything.
    You wrote you have suitable lamps for sale. I am from Austria, where are you from?
  • 06-20-2010 1:01 PM In reply to
    • mantra
    • Not Ranked
    • Posts 5
    Oh sorry, I realized, you are from Denmark.  Shipping within EU will be no problem.
    Just let me know you price for the lamps + shipping cost.
    kind regards, Norbert
  • 06-20-2010 5:44 PM In reply to
    • Dillen
    • Posts 5,008
    Hi Norbert
    The lamps are soldered to either two small pins each or to the little PCB board itself.
    The new lamps will need to be soldered the same way again.
    The lamps are a bit odd but not extremely expensive. You have a PM !
