PhilLondon:
You can effectively only have one N.MUSIC server in the house.
Could you describe your setup... which element (TV, audio) you've got in which room...
P.
I was hoping that maybe the BeoSound 5 would "free up" the N.MUSIC command to be used by the BeoPort if the BeoSound 5 N.MUSIC was re-assigned to DVD or A.MEM. That doesn't seem to be the case.
I have a BeoSystem 3 as video master in the living room with a BeoSound 5 as audio master in the living room. Also in the living room, I have a BeoCenter 2 disconnected from the ML and being used only for DVD.
I have an Avant in the bedroom as a link room.
I have a BeoSystem 1 with BeoVision 4 in the den/gym as a link room. In the same room, I have a BeoPort connected to an iMac.
I think that the only solution to use the LinkPlayer in this setup might be to disconnect the BeoPort from the Masterlink. Then I could connect an airport express to the BeoCenter 2 Aux port. Of course, I would have to make the BeoCenter 2 the audio master in order to use the Aux port and AUX function.
