Ok, just send a pm if you need a TSOP 7000.
I think, you are talking about the stb controller. Sorry, I never had a BS2, so I can`t help here much, I`m afraid. But I know, that BS2 has an stb controller for two devices, assigned as DTV and V.AUX. Maybe the Sky HD box is on your PUC list. If not it should be possible to add the device to your list, maybe by changing the stb controller eprom. I`m not quite sure here. Maybe a BS2 owner can help .....
This is what I found on page 19 reference manual:
"Connect a set-top box* to the V.TAPE,
AV or DECODER sockets on
BeoSystem 2. If the sockets are all in
use, you can also connect a set-top
box to BeoSystem 2 via the close-up
socket panel.
It is also possible to connect a
decoder to either the DECODER or
the AV socket on BeoSystem 2.
Make sure that all connected
equipment is registered in the
Connections menu. For further
information, refer to the chapter
‘Register and use additional video
equipment’ on page 32 in the Guide.
If you have a High Definition (HD)
set-top box, refer to page 22 for
information about connection and
registration. "
Page 22:
"You can connect a High Definition (HD)
source, such as a set-top box or DVD
recorder, to BeoSystem 2. This gives you
access to digital video sources. You can
also connect a PC.
You can also connect these sources to
BeoVision 4.
Make sure you register all connected
equipment in the BeoSystem 2
Connections menu. Note, however, that
connection of HD sources may limit or
change some BeoSystem 2 functions.
These limitations and changes are
described in this chapter.
For further information about the
Connections menu, refer to page 40."
Hope this helps
Stefan
