It's actually the other way around. The disc spins faster when reading the inner tracks, which
are the first on the disc.
But it could still be the motor control.
Replace capacitors, check for cracked solder joints at the power supply board etc. and loop leads
through the rivet vias on both the servo and decoder boards.
That will allow for a much more reliable diagnose - if needed by then.
