Latest post 06-27-2010 8:38 AM by quader. 34 replies.
Page 2 of 2 (35 items) < Previous 1 2
  • 06-22-2010 5:59 AM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    Re: speaker setup
    "It appears my current set up is hdmi connected to a splitter then to Sky HD and PS3
    Sky HD is connected to the DVI"
    I think, Sky HD and PS3 are connected to a HDMI switcher which is connected to DVI-I input....(?), so you can choose between Sky and PS3 on the DVI input, am I right? Because a splitter connected to an input doesn`t make sense.
    "if you connect it to VGA would you not lose the HD quality ?"
    No. You have to connect to the VGA out - it`s labeled "PROJECTOR" - because this output will be activated by pressing FORMAT - 0.
    "If I have to use VGA connection then I will have to get a long lead as my projector is on a ceiling mount."
    Yes. I had 10 metres and it worked fine.
    "Do you have IR connected to control the projector via BEO4"
    Yes. I`m using a Lintronic box for the projector, the screen, lights, blinds...
    Stefan
  • 06-22-2010 6:34 AM In reply to
    • CraigB
    • Not Ranked
    • Joined on 05-19-2007
    • Cannock, W. Mids
    • Posts 76
    Re: speaker setup
    When you press Format and then 0 I believe the picture output is then transfered to the VGA socket, I'm not sure if you would lose HD as a result, Hopefully someone on here will know. You will need to use the VGA connector for you projector though. Also if you do connect your projector with an IR lead you may not be able to control your specific projector with the a Beo4, only the 2 projectors that are in the projector list, you may need to get a software update on your BV7 to add your specific Projector to the list for the Beo4 to control it, I'm not 100% on this so again hopefully some one on here can clarify.
    Just to help anyone that's not seen the connections on a MK1 BV7, heres a picture of the AV3, AV4, DVI and VGA Connections
  • 06-22-2010 7:00 AM In reply to
    • Seanie_230
    • Top 75 Contributor
    • Joined on 04-20-2007
    • Milton Keynes, England
    • Posts 962
    • Gold Member
    Re: speaker setup
    that is correct when you free format 0 the tv changes from its internal display to its external display VGA on this model.
    VGA should give you a very good image anyway i dont think VGA carries HD to be honest but you will get an output.
    Beovision 7 MKIV (Blu Ray)
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Optoma HD65 Projector
    Lintronic TT455-RT-238
    Beovision 3 MKII
  • 06-22-2010 8:06 AM In reply to
    • stefan
    • Posts 1,733
    Re: speaker setup
    As said before:
    You can get HD resolution via VGA, not Full HD, because BV7-32 max. resolution is 1366 x 768. Same as BV7-40 MKI/II.
    And pressing FORMAT 0 will activate the PROJECTOR out (VGA).
    Stefan
  • 06-22-2010 8:21 AM In reply to
    • quader
    • Top 500 Contributor
    • Joined on 08-03-2007
    • West Yorkshire, UK
    • Posts 89
    • Gold Member
    Re: speaker setup
    yes you are right about the DVI connection,
    Is there a name for this cable for the VGA connection,how much is the Lintronic box
    Am I right in that when FORMAT 0 is applied i will be able to control which and how speakers are used.
  • 06-22-2010 3:48 PM In reply to
    • stefan
    • Posts 1,733
    Re: speaker setup
    "Is there a name for this cable for the VGA connection"
    VGA cable.
    "how much is the Lintronic box"
    See www.lintronic.dk You need the -238 box.
    "Am I right in that when FORMAT 0 is applied i will be able to control which and how speakers are used."
    You can choose SPEAKER 1 -5.
    Stefan
  • 06-22-2010 4:55 PM In reply to
    • Seanie_230
    • Posts 962
    • Gold Member
    Re: speaker setup
    Just to add yes you can adjust a different speaker configuration for projector and normal tv mode
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Beovision 3 MKII
  • 06-23-2010 6:47 AM In reply to
    • quader
    • Posts 89
    • Gold Member
    Re: speaker setup
    IS IT POSSIBLE TO CONNECT MORE THAN 4 SPEAKERS,CENTRE AND A SUB
    MY dealer is saying no but i thought I read on the forum something upto 12 speakers
  • 06-23-2010 10:04 AM In reply to
    • stefan
    • Posts 1,733
    Re: speaker setup
    No. Your dealer is right. It´s not the BS3 you have.
    Read the manual.
    Stefan
  • 06-27-2010 8:38 AM In reply to
    • quader
    • Posts 89
    • Gold Member
    Re: speaker setup
    I have managed to get the picture on the projector via a VGA cable connected directly from the tv to my projector. I have now tried to access a menu which should allow me to change my speaker setup, however the only speaker menu i have allows me to change the front and rear from 8000's to 4000's but as my projector is setup at a 90 degree angle from my tv, im basically wanting to see if im able to use 1 beolab 8000 and 1 beolab 4000 as my fronts and the other 2 speakers as my rears. Is this possible? I dont get another speaker setup menu after i connect the projector either? What am i doing wrong? Im getting the curtains on the TV aswel as the projector screen but when i change any speakers settings whilst on the projector..they remain the same when i switch back to my tv.
    I hope this makes sense.
    Thanks in advance.
