Thanks Craig for the pictures there are what I have on my BV7 -32 MK1
It appears my current set up is hdmi connected to a splitter then to Sky HD and PS3
Sky HD is connected to the DVI
if you connect it to VGA would you not lose the HD quality ?
This may be why FORMAT 0 is not working for me.
If I have to use VGA connection then I will have to get a long lead as my projector is on a ceiling mount.
Do you have IR connected to control the projector via BEO4
