Latest post 06-21-2010 4:38 PM by nico vercammen. 2 replies.
Page 1 of 1 (3 items)
  • 06-14-2010 11:39 AM
    can i detect the BV9 is turned on ?
    Is there a trigger to detect the BV9 is turned on?
    I want to connect it to a domitic system.
    A switched output is ok, whatever voltage
    Is the  "DTV Data" connection on the BS3 sending data ?
    I can do it by measuring the used power, but a direct connected status should be easier ...
    nico
  • 06-14-2010 12:25 PM In reply to
    Re: can i detect the BV9 is turned on ?
    I guess you could test the power on one of the SCART socket.
    The official way to integrate a Home automation system and B&O is the MLGW box.
    Expensive, but you'll get 2 way communication:
    The home automation system knows the status of each TV, and you can send commands to your home automation system with the Beo5 or the new Beo4.
  • 06-21-2010 4:38 PM In reply to
    thanks ! , but i found another way to detect it.
    pin 1 of the powerlink connector for the center speaker will go to 2,5 V when the TV is on.
    This way i can detect only when the TV is on and not when the radio is on because this speaker is only used in a TV setup.
    nico
