Latest post 06-14-2010 4:50 PM by elephant. 3 replies.
Page 1 of 1 (4 items)
  • 06-14-2010 2:18 AM
    dvd 1
    I   i got dvd 1  and a video projector  I would like to know if I can use beo 4 remote control via my projector I can play dvd right now but I don't have access to the menu  thanks a lot
  • 06-14-2010 3:11 AM In reply to
    Re: dvd 1
    That will depend on whether you have a BeoVision environment that is based on the beosystem 3 (or predecessor) video processing technology and whether the projector is supported.
    Can you please list what is the TV, and what is the projector.
    First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
  • 06-14-2010 10:24 AM In reply to
    Re: dvd 1
    no tv just a video projector  japanese brand call  oley        thanks
    Filed under:
  • 06-14-2010 4:50 PM In reply to
    Re: dvd 1
    atomic:
    so you have the B&O DVD1 direct to the Oley projector ?
    and no other B&O equipment ?
    It is not my area of experience but I think you are out of luck.
    The only suggestion is that the Beo5 remote may be able to control both units.
    I suggest you re-ask the question in the Beo5 forum or send a Personal Message to Keith Saunders who is the Beo5 expert
