Latest post 06-24-2007 3:05 PM by mobeyone. 5 replies.
Page 1 of 1 (6 items)
  • 06-24-2007 1:55 PM
    LC1/2 and CFLs... can they be used togther?
    I have always been led to believe that energy saving bulbs cannot be used with B&Os light controllers, but according to this site.
    If I am reading this right, I can use this with an LC1 or 2? can anyone confirm? or have any thoughts?
  • 06-24-2007 1:59 PM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Re: LC1/2 and CFLs... can they be used togther?
    Looking at you link Mobe, I would say yes. They seem to be specially made for just that purpose.
    CraigBig Smile
  • 06-24-2007 2:04 PM In reply to
    • frog
    • Top 500 Contributor
    • Joined on 04-19-2007
    • Posts 191
    They can, but you have to set up the LC2s to switch on and off without fading.
  • 06-24-2007 2:09 PM In reply to
    frog:
    This is what "confuses me Wink
    I am with Craig in that the site confirms that you can use the bulb with a dimmer switch? I dont think you have as much control as say an incandescent but you have some form of dim? and not just a case of off and on?
  • 06-24-2007 2:32 PM In reply to
    • Jandyt
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Hiya Mobe.
    I have never come across these bulbs before. You do realise they have 4 pins, don't you?
    I know you can program LC2 to be on/off instead of dimming, in which case they can be used with flourescent lights, but I don't think LC1 has the same ability.
    Just been and checked. The wording in the manual says "The LC 1 is designed exclusively for the connection of incandescant lamps. Their italics.
    Have you checked where you can get a 4 pin lamp socket?
    Andy T.
    Poor me, never win owt!
  • 06-24-2007 3:05 PM In reply to
    Hey Andy,
    They are the right bulbs! The lamps are by Louis Poulsen and are all 4 pin as above, I think its all this green malarky that LP has jumped onto....
    But to me the site advises that the problems with CFLs previously are no more due to a change in design which makes them safe to use with a dimmer and can mimic a incandescent light bulb without causing problems.. such as a fire!
    To be honest, I probably will not use the dim function and just have it set to on/off.. but still a nice feature to have!
    m
