        1st March February 2012
	    Latest post 06-09-2010 12:49 PM by  beojeff. 11 replies.
								        05-29-2010 4:19 PM
									        cabj
								                - Joined on 12-13-2009
								                - Posts 17
										    Beosound 5/Beomaster 5 dead!?
										    Today my beosound 5/beomaster 5 died it seems - anyway the dreaded Windows blue screen appeared on the display. Ok - it started when I was playing a song, then all of sudden it sounded like an old record playng the same track  all over again. I unplugged my devices, and I had to choose between starting up as usual or make a reset, by pressing F8, but how do I do that? I don't own a windows computer, but a a Mac. so nothing could be done. So I unplugged my devices again, and now the screen said similar to this: in order not to damage  your pc we shut down. So.. anybody out there, who might help, or do I have to get my system to service (6 months old, still 18 months warranty). Thanx for any help whatsoever.
greetings Carsten
									        Keith Saunders
								                - Joined on 04-16-2007
								                - Technical Advisor, Little Ann, Hampshire, UK
								                - Posts 3,810
										    Re: Beosound 5/Beomaster 5 dead!?
										    Carsten,
Very sorry to hear that your BeoMaster/Beosound 5 has failed.
The Windows "Blue Screen" is generally quite a fatal error and can be caused by a very large number of different failures particularly disk and memory related.
The Beomaster 5 is just a Embeded Windows system with the Beosound 5 communicating as if it were a monitor, keyboard and mouse, it asks you to press F8 it knows nothing about the fact it is a Beosound 5, it thinks you have a standard keyboard.
As it is under warranty you should get it fixed by your dealer under warranty.
									        cabj
								                - Posts 17
										    Thanks for the speedy reply. Of course you are right about WIndows and F8, I remember now from my Windows days. So off it goes to the dealer.  I had hoped that you could reboot the system by pressing go in any combination with the > or > key, or holding down the on/off  button. But just blinks, and finally the light is out.
Kind regards,
Carsten
									        csmager
								                - Joined on 05-09-2008
								                - Posts 213
										    If you've got a USB keyboard, you could try rebooting with that attached.
Though if you manage to get it to boot and it bluescreens again, then it's dealer time.
									        cabj
								                - Posts 17
										    ok, I'll try that if I can find an old usb keyboard stuck away somewhere. But if I connect a keyboard then the BM5 is not connected to the BS5, is that not a problem?
Kind regards
Carsten
									        jk1002
								                - Boston USA
								                - Posts 1,620
										    You can use the BM5 standalone. Is probably a disk failure I would think. I would see a dealer regardless.
									        GRebitzer
								                - Joined on 05-16-2009
								                - Posts 15
										    Hello Carsten,
I had the exact same issue you describe last year. It took a while for the dealer to find out what the problem was, but in the end it was a failure of the motherboard. Apparently the initial motherboard had these problems and was replaced by a new design just before the XMas production in 2009. You might still have the old motherboard. I recommend to point your dealer to this and hope that this will then sorted out.
Best,
Gerald
									        cabj
								                - Posts 17
										    Hello Gerald,
Thanks a  lot for your reply, I'm glad  that we have narrowed down the problem, I will point out to the dealer the issue with the moherboard, so that I will hopefully get my system back quickly  It seems that there is nothing you can do on your own. In the meantime I will have to do with my Apple Tv which is not connected to my Beolab - only to my TV
Kind regards,
Carsten
									        cabj
								                - Posts 17
										    Thanks for your reply. you are probably right, HD failure, anyway I'll see the dealer, pretty irritating though thinking of all the money you paid.
Kind regards,
Carsten
									        sjmcguckin
								                - Joined on 05-28-2010
								                - Posts 43
										    Hi Gerald,
My Beomaster 5 has suffered the same fate and gone for a new motherboard. When they replaced your motherboard did it still have the DVI-I socket or was this upgraded to HDMI? I don't know why this product doesn't have an HDMI socket. It would certainly reduce the cabling to the BV7
Regards
Stephen
									        GRebitzer
								                - Posts 15
										    Hello Stephen,
my new one does not have HDMI, but maybe it will come?
Gerald
									        beojeff
								                - Joined on 11-29-2007
								                - Posts 543
										    I, too, have been getting the blue screen since my BS5 software update. It returns to normal if I unplug the BM5, wait 15 seconds, and plug it back into the power. However, when I return home in the afternoon after work, it agains has the blue screen. I'm backing-up the music files to be prepared.
        Page 1 of 1 (12 items)
