        1st March February 2012
	    Latest post 05-25-2010 1:27 PM by  IngvarW. 9 replies.
								        05-24-2010 9:44 AM
									        IngvarW
								                - Joined on 10-09-2007
								                - Sweden
								                - Posts 108
										    Hello, I am thinking of a switch from a pair of BL8000 to four BL3s for sorround, etc and perhaps a BL11.
There are used ones of BL3 on the net for approx 70% of the price of new ones but they are from 2006. Does anyone know if there has been any updates och upgrades since 2006 of the speakers?
Brgds Ingvar
									    Collector since 1996, BS5/BM5, BL3*4, BL11, BEO6, BV10-46, BL2000, MX4002, Beocom6000, Beotalk1200
									        hebo
								                - Joined on 04-16-2007
								                - Sweden
								                - Posts 305
										    Re: Updates/Upgrades for BL3
										    Hej Ingvar
I´ve heard those who think the BL3 is a big waste to have as a rear-speaker in a sorround setup.
They are very nice looking but - Why dont keep the BL8000 as rear.
Just my opinion.....
									        macjonny1
								                - Joined on 11-08-2009
								                - Posts 355
										    There has not been an upgrade and one isn't needed.
I think the BL3 front and BL8000 rear as suggested would look a little funny....
									        IngvarW
								                - Sweden
								                - Posts 108
										    The wife wants smaller speakers and what can I do :-). Maybe smaller in the background. Thanks Brgds IW
									        burantek
								                - Joined on 05-04-2007
								                - SE USA
								                - Posts 6,214
										    There actually was a revision to the BL3 in about 2007 going from Mk1 to Mk2...
Woofers replaced/upgraded -or something similar?
++++EDIT++++
...found a thread w/ some details of the change(s).
									        Clakke
								                - Joined on 02-01-2009
								                - Sweden
								                - Posts 108
										    Hi
I think Hebo is right. It sounds like overkill to have BL3 as rear speakers. BL3 is almost as good as BL8000, some say they are better. I think you could get away with something cheaper for the rear from some other company.
B R
Clakke
									        macjonny1
								                - Posts 355
										    It's amazing that wives are the same no matter what country you are in!
I think you are doing the right thing to do whatever she says!
									        beocool
								                - Joined on 10-17-2007
								                - the Netherlands
								                - Posts 5,514
										      Clakke:
I think BeoLab 3's are more detailed and a little faster than the Beolab 8000's. I also think they're better at low frequencies. Beolab 8000's are a bit smoother.
									        Clakke
								                - Sweden
								                - Posts 108
										      beocool:
Hi
Yes, they are quite equal in performance, I believe. It is probably very dependent of the environment where the speaker act. I can not say that I have heard BL3 sounding better than BL8000 though (in any setup). The sound from BL8000 and BL3 seems to be very matched to each other, so I think they would work great together in a surround setup. It would probably be overkill for most people, both are so very fine stereo speakers. The prices seem to have gone up these days in a way that it is questionable if they are worth it today though, specially for BL8000.
BR
Clakke
									        IngvarW
								                - Sweden
								                - Posts 108
										    Hello Again. Actually I suddenly got OK from the wife for a new 10-46 which will arrive on monday  .
The plan for BL3s in the back is that they will then fill up the whole room and also make sound out in the kitchen/diningroom. I guess the BS5/BM5 can play in some music mode for all speakers via the BV10-46 so there will be a stereopicture with 2 left and 2 right of the BL3s. Is that correct anyone?
Brgds Ingvar
        Page 1 of 1 (10 items)
