Latest post 05-19-2010 8:53 AM by Topsy. 10 replies.
Page 1 of 1 (11 items)
  • 05-15-2010 5:53 AM
    • Topsy
    • Not Ranked
    • Joined on 05-15-2010
    • Posts 7
    Beosound 2
    Hi I am new this this forum. I have just purchased a 2nd hand Beosound 2 MP3 player and unfortunately I seem to have brought a dud. The reason for this is that i cant get it to register with my laptop. I am using windows 7. The laptop does not recognise it when I attached the usb lead. The charger does not change colour as i believe it should do. Any help welcome, I just want to appriciate the excellant sound of B & O
  • 05-15-2010 8:03 AM In reply to
    • Vienna
    • Top 100 Contributor
    • Joined on 08-15-2008
    • make an educated guess
    • Posts 712
    Re: Beosound 2
    Unfortunately there exist no Windows Vista and Win 7 drivers for BeoSond 2
    You willl have to switch your BeoSound 2 to the "mass storage" or "iTunes" mode:
    - press ^ (arrow up) and << simultanously and !! KEEP THEM PRESSED DOWN !!
    - press GO twice
    - when BS 2 changes to iTunes mode you will get a beep (confirming the mode change)
    - release ^ (arrow up) and <<
    In iTunes-mode you can use Windows Explorer or Windows MediaPlayer or iTunes
    to transfer music to the BeoSound 2
  • 05-15-2010 5:44 PM In reply to
    • Stan
    • Top 150 Contributor
    • Joined on 04-17-2007
    • Posts 593
    • Gold Member
    Re: Beosound 2
    You also need to have the headphones attached while perform the above procedure.
    Stan
  • 05-15-2010 9:07 PM In reply to
    Re: Beosound 2
    You will also need to explain why you bought a BeoSound 2!
    There is scarcely anything in this world that some man cannot make a little worse and sell a little more cheaply. The person who buys on price alone is this man's lawful prey. - John Ruskin
  • 05-17-2010 8:04 AM In reply to
    • Topsy
    • Not Ranked
    • Posts 7
    Re: Beosound 2
    Hi I purchased the Beosound 2 as an introduction to b & o.  It is second hand and was a good price.  I am only a casual user and quite happy to listen to any music without the need of a display screen. My thoughts are that I load the music therefore I must like it.  I have a final question, the base lead has two leads coming from it, a usb connection and what appears to be a data telephone connector, whilst I understand the need for the usb I dont understand the data connection, is this normal?
    Thanks for all your help
  • 05-17-2010 9:40 AM In reply to
    Re: Beosound 2
    The tel. jack plugs into the power supply so the charger can plug into the wall and charge the unit.
  • 05-17-2010 3:26 PM In reply to
    • archie
    • Joined on 04-16-2007
    • Paris
    • Posts 497
    Re: Beosound 2
    hello
    It's more easy to use SD card reader to transfer music from PC to BS2.
    DU BEAU, DU BON, DU BO.
  • 05-17-2010 5:26 PM In reply to
    • Stan
    • Posts 593
    • Gold Member
    Re: Beosound 2
    Hopefully, you got the power-supply with the unit because it must be plugged in to charge (I think - I have never done it any other way).  That is, I don't think the dock works unless it is plugged in... it is not just usb powered.
    Stan
  • 05-17-2010 11:14 PM In reply to
    Re: Beosound 2
    There is also a separate charger with a lead and an unusual connector that plugs straight into the BeoSound 2
    I carry it on overnight trips so I can recharge
    Should still be available from B&O and coupled with the earlier suggestion of swapping SD cards may be the cheapest route to getting a recharger
    Alternatively source the missing hub charger from B&O as a spare part
    First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
  • 05-18-2010 5:21 AM In reply to
    Re: Beosound 2
    Hi
    If you are using W7 Ultimate you can download Windows Virtual PC (W-xp mode). Then it is possible to run the player and usb drivers in XP.
  • 05-19-2010 8:53 AM In reply to
    • Topsy
    • Not Ranked
    • Posts 7
    Re: Beosound 2
    All  now sorted and finaly manged to charge and listen to the BS2. The sound is great and will now enjoy showing off to my mates.
