Latest post 05-14-2010 11:15 PM by elephant. 4 replies.
Page 1 of 1 (5 items)
  • 05-13-2010 6:31 AM
    • quader
    • Top 500 Contributor
    • Joined on 08-03-2007
    • West Yorkshire, UK
    • Posts 89
    • Gold Member
    HD projector setup with BV7-32 ?
    Does anyone have this setup ?
  • 05-13-2010 6:39 AM In reply to
    Re: HD projector setup with BV7-32 ?
    Yes, I do.  Since my first generation BV7-32 cannot connect to a projector directly, so my setup is like this.  Panasonic Blu-ray player's HDMI output to Panasonic PTAE4000 projector and the Blu-ray player's digital audio output to BV7-32's digital audio input.  So the BV7-32 will have a blank screen but it'll output surround sound to the speakers.
  • 05-13-2010 6:41 AM In reply to
    You will be able to get a set up like this, using a HDMI splitter. There is one from Gefen, B&O compatible ;) link
    Jq. BS4 BL3 A8 Form2
  • 05-14-2010 3:59 PM In reply to
    • quader
    • Posts 89
    • Gold Member
    I attempted to connect a HD projector to my SKY HD Box where i had picture but no sound. How do i get the sound from the Beolabs? Also, how did u manage to get a blank screen as when i connected the projector to the Sky box my tv was showing the picture also. I then tried turning the Tv off but the Beolabs (8000 & 4000) turned off.
    Thanks in advance.
  • 05-14-2010 11:15 PM In reply to
    quader:
    program your Beo4 for "P.MUTE" which is "picture mute" -- I know the phrase is nonsensical :) but it does turn the screen off ... pressing it a second time "unmutes" the screen and you have your vision back
    First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
