Latest post 05-11-2010 6:03 PM by j0hnbarker. 7 replies.
Page 1 of 1 (8 items)
  • 05-11-2010 1:55 PM
    Beomaster 1000 Question
    Evening all :)
    Got a Beomaster 1000 today from eBay for £25 on a BIN! It's pretty flawless and all works fine except that the mains cable has been cut at some point and is about 2' long. I'd rather not splice another in as I don't have anything to join it up with. Is it an easy job to just replace the mains cable at the transformer end, and if so, how do I get the thing apart??
  • 05-11-2010 2:09 PM In reply to
    Re: Beomaster 1000 Question
    j0hnbarker:
    The BM itself?
    (5) screws on bottom (graphic provided on bottom).
    (2) on each side visible thru the "slots" and (1) roughly center in the grill that has a long spanning body.
    P.S. Congrats on a cool piece! Yes -  thumbs up
    • B&o bottle opener
  • 05-11-2010 2:18 PM In reply to
    Thanks Jeff!
    I might take a look. One other question. I have an input from my Airport Express running into an adjacent Beolab 5000 amp. Is there a 5 pin DIN output on the 5000 amp that I could use to connect the 5000 and the 1000 together, so that the 1000 can take the feed from the 3.5mm to 5 pin DIN jack that's connected to the 5000 - if that makes sense??
  • 05-11-2010 2:42 PM In reply to
    I suppose you could use the tape out - there are lots of connections on the 5000 so take your pick! There is also a line out in both DIN and RCA.
  • 05-11-2010 2:59 PM In reply to
    Thanks Peter - I'm currently using the tape in on the 5000 to hook the Airport Express in. Will the line out still work, or would I be better swapping the Airport over to something like the Aux in?
  • 05-11-2010 3:10 PM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Is it a black or white key model John?
    CraigSmile
  • 05-11-2010 3:17 PM In reply to
    It's black Craig - I would have prefered a white keyed one but for £25 beggars can't be choosers :)
  • 05-11-2010 6:03 PM In reply to
    I popped a photo of this on the 'Flash Your B&O' thread :)
