1st March February 2012
Latest post 10-20-2011 4:56 PM by Griebel. 21 replies.
05-09-2010 9:16 AM
northswede
- Joined on 04-29-2010
- Stockholm, Sweden
- Posts 32
Is it possible to use BeoMedia 1 without turning on your TV?
Hi Everybody, I'm not sure if this fits in general but I'll give it a try.
I'm thinking of buying an BeoMedia 1 and connect it to my TV, but is it possible to use n.radio without waking up the TV monitor? The idea is to get n.radio and n.music, but I would prefer to use my remote or BeoPlayer software to control the BeoMedia.
I have my speakers connected to my TV (BeoVision 7).
Regards
Swede
Current collection: BeoVision 7-40 mk III, BeoLab 7-4, BeoLab 3 and BeoSound/BeoMaster 5.
Seriously, it's a beautiful package of excellent and awesomeness!
PhilLondon
- Joined on 04-16-2007
- London
- Posts 2,545
Re: Is it possible to use BeoMedia 1 without turning on your TV?
You can call N.RADIO or N.MUSIC from any room without waking up the TV, but only if you have a N.MUSIC compatible Audio System as well.
(BS3000 with recent software, BS9000 with recent software, Beosound 4, Beocenter 2).
P.
northswede
- Stockholm, Sweden
- Posts 32
Thanks for the quick reply!
So the BeoMaster 1 can't act as a Audio Master (Long time fan, but new to actually use B&O equiptment)? Do I have the same limitations with an BeoPort connected to a PC with BeoPlayer?
//S
PhilLondon
- London
- Posts 2,545
Beoport connected to PC can act as an audio master, or connected to a Mac with LinkPlayer as well.
Beomedia 1 cannot act as an audiomaster. Beomaster 5 can, even without a Beosound 5.
DrDimitris
- Joined on 04-25-2007
- Posts 560
PhilLondon:
Not so true i am afraid. In my system (BV7, BeoMedia1, and Beoport/PC/Beoplayer/IR) it has never acted as an audiomaster.
PhilLondon
- London
- Posts 2,545
As you can see below, you can set Beoplayer (Beoport) in option 0. Works like a charm. The PC's CD player even works when you press CD on the remote.
Beomedia 1, however does not have this option.
northswede
- Stockholm, Sweden
- Posts 32
It seems that the better choice for me, would be an BeoPort/BeoPlayer combination before an BeoMedia 1 at the moment.
Thank you both for your input.
//S
PhilLondon
- London
- Posts 2,545
However, with the Beoport, the downside is that you do not get onscreen navigation, as it does not respond to the PC key. Unless you've got a dedicated PC, then you'll won't be able to hear any "normal sound" that your PC is doing unless you use the TV's speakers.
Using a Beomedia, you could select your music on screen and then mute the picture.
Using a Mac mini, you could use both N.MUSIC, N.RADIO, CD (Audio master) and also use with onscreen media navigation.
DrDimitris
- Posts 560
PhilLondon:
I have tested it in options 2 and 6. I will try option 0 as you suggest and see. Main PC should be Yes or No when you have the Beomedia also linked?
Beobuddy
- Joined on 04-18-2007
- Posts 1,582
The option "main PC" has to do with the question : Does this PC distribute the music to the link?
If you're only having a beoport without the Beomedia, then the answer is : Yes.
If you're having a Beomedia, then the Beomedia is the main PC, and the option has to be set to : No.
If you have more then 1 beoport, but no Beomedia, only one PC with beoport is set to "yes", that's the one with the music files.
I'm having the Beomedia for some time now, and I really enthusiastic about it. When you're installing Beoplayer on any other pc, it plays the music from the Beomedia as well.
Works very good. I have one (a second one I don't use) for sale by the way, with a 500GB harddrive. Look at the Private Sale Section.
Beobuddy
- Posts 1,582
I never tried option 0.
Normally it has to do with the optional ir-eye.
It responds to Link-PC/Vtap2e/VAux, when opt 4 is used.
So, option 0 will probably make the BM1 a kind of slave.
BTW, what I discovered is, that when you disconnect the ML cable from the BM1 and then enter the setup (settingsmenu) from the BM1.
Then after 2 seconds you can change the command where the BM1 has to respond to. Normally it is "PC".
But when you change it to V-Aux, then the BM1 can be used with older equipment which do not know the PC command.
PhilLondon
- London
- Posts 2,545
DrDimitris: Thanks Beobuddy! Do you confirm that option should be set to 0?
Just did a bit of testing, and in fact you must set the Beoport to Option 2 to make it act as an audiomaster.
N.MUSIC, N.RADIO and CD will be distributed from the Beoport to all rooms.
Heribert
- Joined on 08-06-2009
- Austria
- Posts 592
If the music is on your pc you need a Beoport. Beomedia has it's own music library. Not sure you can also stream music from your pc.
BeoVision 8-40 / BeoVision 8-32 / Beovision 6-26 / BeoSound 3200 / BeoSound 1 / BeoLab 3 / Beolab 6000 / Beolab 2000 / Beoport / Beomedia 1 / 3* Beo4 /BeoCom 5 with VOIP
PhilLondon
- London
- Posts 2,545
No, you can't, because your Ouverture isn't N.MUSIC compatible.
hfat
- Joined on 05-18-2010
- Austria
- Posts 176
Yes, You could use Beomedia 1 with your Panasonic TV. But you have to use additional equipment. I personally like the minimalistic style of BeoMedia1 more than iTunes.
You cold make it work, with an additional IR-eye and a lintronic TT455-RT-238 box.Configure the BM1 as it is done with older B&O TVs which do not support the PC command. Connect video to the TV and audio to the A.Aux to the overture (the adapter should be available at your B&O shop). To make it work at the press of one key on your Beo4 you have to use the lintronic box. It's a little bit tricky, but can be solved. If it's worth, ist up to you.
hfat
PhilLondon
- London
- Posts 2,545
hfat: You cold make it work, with an additional IR-eye and a lintronic TT455-RT-238 box.
I am not sure why you'd need the TT455 box. Just an external B&O IR Receiver and that should work.
p.
hfat
- Austria
- Posts 176
You are right about the TT455.
If you dont't want to use BM1 by pressing a single button you can forget about the TT455.
In this case you would set the overture to A.Mode 1 and configure the BM1 to listen to V.Aux command.
You first press A.Aux to start Overture, then you start BM1 with V.AUx command.
hfat
kimhav
- Joined on 09-03-2007
- Sweden
- Posts 127
Regarding the Beomedia 1 and navigating without having the TV on; well that works fine. But, what I'm struggling with when using BeoPlayer to maintain playlists, etc on the Beomedia is that everytime when I start up BeoPlayer on a PC it starts to scan and rebuild the database and with around 200gb mp3 files that takes a while. Are there any way of disable this painfull process of re-scanning media? Also, when scanning it seems as it does it from scratch. At least when I let BeoPlayer scan on another dedicated media system it's re-scans and only looks for newly added files which usually only takes 5-10 minutes and not 2-3 hours...
Griebel
- Joined on 03-09-2008
- Posts 122
Nope, it's not possible to switch off the scan, which by itself is not a problem, but it activates BeoNetMusic, which is very annoying. I think the only possibility is to disconnect from the web, but that's not a viable solution.
Page 1 of 1 (22 items)
