Six months ago i bought a new Beovision 8 32 with system module and BE04 Remote Control. This was coupled in January with a Sky + HD set top box (Amstrad). At first the system worked well but I had some problems with the Sky box crashing about twice a week. After much discussion with Sky in April this year - about ten days ago they replaced the box with a Pace HD unit which works OK. However i now have problems with the B&O TV which has progressively deteriorated, that is
1 No Digital TV
2 BE04 will not configure the AV sockets. Opening Video Aux allows the Sky programs to run if the Sky remote is used to click on and then open the TV guide only from the SKY remote.
3 The Beo DVD will only respond to click the BE04 DVD key but the video can not me managed, just started and stopped
4. Turning off with the BE04 does not close the TV program but doers not put the set into stand by, it has to be disconnected from the A\c power.
The local B&O shop that sold me the TV maintains that the problems are caused by the SKY feed whereas Sky say the the B&O TV is known to be faulty. I am very disappointed with the B *32 as I have had several B&O TV's over thirty years and had no problems; I thought that the latest generation would be similar. Alas!
It looks as if I will have to abandon the B&O TV and buy a more common brand if other members can suggest a better way to resolve these technical difficulties?
