Hi all
Just a heads up, don't update your BS3 SW to the latest version(started from 8.05) if you are using a BV4 Plasma screen. I had mine upgraded, and since then, the picture is very dark when turning the tv on, i can get the picture to its normal self again with either one of 3 methods.
1. Placing a hand on the lightsensor for aprox 5 seconds.
2. Running Automatic Color Management manually
3. Adjusting the contrast setting in picture menu(by one click), this doesn't wotk always.
SW 8.12 has not solved this issue, so i must wait until the next SW is released.
/Weebyx
