Latest post 08-06-2010 7:35 PM by andreabang. 16 replies.
Page 1 of 1 (17 items)
  • 05-04-2010 3:01 AM
    • Weebyx
    • Top 200 Contributor
    • Joined on 06-30-2008
    • Denmark
    • Posts 321
    Dark picture on BV4 with SW 8.05
    Hi all
    Just a heads up, don't update your BS3 SW to the latest version(started from 8.05) if you are using a BV4 Plasma screen. I had mine upgraded, and since then, the picture is very dark when turning the tv on, i can get the picture to its normal self again with either one of 3 methods.
    1. Placing a hand on the lightsensor for aprox 5 seconds.
    2. Running Automatic Color Management manually
    3. Adjusting the contrast setting in picture menu(by one click), this doesn't wotk always.
    SW 8.12 has not solved this issue, so i must wait until the next SW is released.
    /Weebyx
  • 05-04-2010 6:12 PM In reply to
    • YannChris
    • Joined on 04-16-2007
    • Larmor-Plage, France
    • Posts 276
    Re: Dark picture on BV4 with SW 8.05
    Hi!
    Same thing for me.
    My dealer flashed my BV9 yesterday with sw 8.12 and it did not solve the problem.
    He checked in the B&O intranet, this problem is mentioned in the "known issues" section... without any delay for correction of the default and no work-around.
    We have to wait, unfortunately.
    Yann.
    Ne pas s'en faire et boire frais!
    Mon install en images: cliquez sur mon profil, au dessus de mon avatar - Puis "My files" tout en bas.
    Pictures of my setup: click on my nickname, above my avatar. Then "my files" at the bottom of the page.
  • 05-05-2010 9:27 AM In reply to
    Does this "dark picture" occur on Beovision 7-40 (markIII and markIV) and 7-55 also with sw 8.xx???
    Regards
    Beolab 5 with sw 3.0,  BV7-55 3D without Bluray(MK II), Beolab 7-4, Beolab 4000 MKII, Beolab 3500, Beovox CX100, Beosound 9000 mkIII, Cabinett 2054, Beo4 MKII, Oppo BDP-93 Blurayplayer (B&O-version)
  • 05-11-2010 9:42 AM In reply to
    i experience(when upgraded to 8.XX software) the same bug on my BS3 with Bv 4-50 bezel front.....no solutions?this is not admissible
  • 05-12-2010 4:19 AM In reply to
    • Weebyx
    • Denmark
    • Posts 321
    No solution yet, i have written directly to B&O and they have not responded yet !
    Maybe if we all wrote to them ?
    /Weebyx
  • 06-29-2010 9:14 AM In reply to
    • Weebyx
    • Denmark
    • Posts 321
    I have been in contact with my dealer today, and a new SW fixing this problem is expected in about a month from today, they offered me a service release which is basically a Beta version, but since i have to drive 600km to get i flashed, i will wait until the final release :)
    /Weebyx
  • 06-29-2010 9:19 AM In reply to
    My BV50/BS3 was updated with the latest sw (8.xx) when it was installed a few months ago and I thought it was dark as well, but since it was a new TV to me...I didn't know that it was not supposed to look that way! I hope we get a sw fix soon, thanks Weebyx.
  • 06-29-2010 9:21 AM In reply to
    Not a problem on a BV7-40 Mark 3
    Train Hard - Run Fast - Hit to Kill!!!
  • 07-07-2010 1:50 PM In reply to
    I experience the dark picture bug also in the version 8.12a of my Beosystem 3 just updated.It's random,sometimes clear imagine,sometimes dark,i noticed it happens also during watching tv!!!!The funny things is that when the technician came it was all ok....
    I think It's something about the contrast,when i go to modify it,it repair the bug screen..
    I'm really disappointed.....any suggestion?
  • 07-07-2010 2:04 PM In reply to
    My BV4-65, purchased november 2009 have had same kind of problem. The picture is a little bit dark and some details in movies are missed. Sometimes it suddenly appear brighter and what a marvellous picture it becomes. I am told they are working on it and the problem will be fixed in about a month.
    Ahmet1
  • 07-21-2010 7:25 AM In reply to
    • Weebyx
    • Denmark
    • Posts 321
    Today i had my BS3 upgraded to 9.01, i cant wait to connect it to the system when i get home later, i will keep you posted on how it goes :)
    /Weebyx
  • 07-21-2010 8:15 AM In reply to
    9.01...it seems a major update!
    waiting your impressions...
  • 07-21-2010 10:33 AM In reply to
    • Weebyx
    • Denmark
    • Posts 321
    It seems that the dark picture issue is solved, i have to make some more tests tonight, but for now it looks great.
    Other new things are.
    * Sleep Timer(how it could take B&O 1 million years to implement that i dont know?) :)
    * Naming of Sources, e.g DTV2 = "MediaCenter"
    * "Game mode" under picture settings, don't know what it does.
    * New DVB-HD logo instead of that hideous clock screen
  • 07-26-2010 5:03 PM In reply to
    today i update to 9.01!!(bs3+bv 4-50)
    It seems the bug screen is solved!
    I noticed another bug...when i use Picture In Picture between PS3 and tv(apple tv) only one picture is shown....maybe the panels can't handle both signals simultaneously(between ps3-tv or appletv-tv, it works flawless) ??
    I turn off/on game mode,but i didn't notice anything different....what it does exactly??(BTW is quite uncomfortable to use....)
  • 08-06-2010 4:17 AM In reply to
    i'm afraid to say but....no, the 9.01sw doesn't solve the bug screen completely,i sometimes experience the dark picture.
    i'm frustrated,i'm tired to bring my BS3 to the assistance for nothing...i'm not a beta tester.
    Sad
  • 08-06-2010 3:24 PM In reply to
    • Weebyx
    • Denmark
    • Posts 321
    That's to bad, under what circumstanses did you experience it ?
    I have not had the issue since 9.01, can you solve the problem by running ACM or covering the lightsensor for aprox 10 seconds ?
    /Weebyx
  • 08-06-2010 7:35 PM In reply to
    i have the old panel (D8) without ACM.Beovision 4-50 with bezel front...
    i try to modify the contrast....but it doesn't solve anything(i have to set the contrast at the higher level to get the original picture )..Apparently i have to switch on/off tv several times to "fix" the problem....
    mah...there aren't any B&O technician lurking in the forum that can say something official about this bug??
    thanks
    andrea
