Latest post 06-23-2007 5:39 AM by monster900. 3 replies.
Page 1 of 1 (4 items)
  • 06-22-2007 4:17 PM
    OVERTURE AUX CONNECTION
    Can a non B&O piece be connected to the aux output easily?
    It says in the manual only data-link items but is this true.
    As a point of interest, im trying to link a Marantz IS201 i pod dock
    using a cable supplied from the same shop i bought the docking station from.
    It is a 5 pin connection to 4 standard pins White red black and yellow.
    Would be grateful, thought it was going well fingers crossed
    Filed under:
  • 06-22-2007 4:34 PM In reply to
    Re: OVERTURE AUX CONNECTION
    That will work fine. Ridax actually does a lead - see here - that allows you to control the iPod with your Beo4 when connected to your Ouverture.
  • 06-22-2007 6:14 PM In reply to
    • Graeme
    • Top 500 Contributor
    • Joined on 04-16-2007
    • Aberdeenshire Scotland
    • Posts 194
    I would say it would work fine however Peter is right Ridax's dock is the mutt's nut's WRT docking an ipod with B&O I have to get one for myself at some point
    Cheers Graeme
  • 06-23-2007 5:39 AM In reply to
    thank you for replies
    D
