- check all ML plugs beeing plugged in firmly
As a first step you should set again the options of all units and check confirmation (LED "twinkling")
- all components have to be in standby
- BC 3200: set A.OPT to 0 / 1 / 2 (dependig on your main room(s) config w/wo speakers connected to BS3200)
- Avant: set V.OPT to 1 /2 (dependig on your main room(s) config w/wo speakers connected to BS3200)
- BLb3500: set L.Opt to 6
! Disconnect all components from power for minimum of 2 min !
Restore power and let the system autoconfig (don't use your remote for 1 min)
If this does not help you'll have to check the cables / junction box
