Latest post 04-24-2010 6:34 AM by Vienna. 3 replies.
Page 1 of 1 (4 items)
  • 04-24-2010 2:06 AM
    • benjnz
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Auckland NZ
    • Posts 392
    • Gold Member
    ML Grief
    Help, I'm obviously doing something wrong. I've just moved around my Avant, BS3200 and BL3500. Just wall mounted the BL3500 and new cable to account for it, however I get everything back on and using the remote for a source on the BL3500 it turns on, shows the source and then goes back to standby. What deliberate thing have I missed in my wiring? Indifferent
  • 04-24-2010 4:35 AM In reply to
    • Vienna
    • Top 100 Contributor
    • Joined on 08-15-2008
    • make an educated guess
    • Posts 712
    Re: ML Grief
    - check all ML plugs beeing plugged in firmly
    As a first step you should set again the options of all units and check confirmation (LED "twinkling")
    - all components have to be in standby
    - BC 3200: set A.OPT to 0 / 1 / 2 (dependig on your main room(s) config  w/wo speakers connected to BS3200)
    - Avant: set V.OPT to 1 /2  (dependig on your main room(s) config  w/wo speakers connected to BS3200)
    - BLb3500: set L.Opt to 6
    ! Disconnect all components from power for minimum of  2 min !
    Restore power and let the system autoconfig (don't use your remote for 1 min)
    If this does not help you'll have to check the cables / junction box
  • 04-24-2010 5:18 AM In reply to
    • benjnz
    • Auckland NZ
    • Posts 392
    • Gold Member
    Re: ML Grief
    Thanks for that I've come to the conclusion one of my junction boxes (the oldest one) was a bit munted, typical though - I nearly bought another one from B&O today but decided not too - sighs! Super Angry
  • 04-24-2010 6:34 AM In reply to
    • Vienna
    • Posts 712
    Re: ML Grief
    benjnz:
    ;-)   ... j-boxes do not have a "second live" (and should preferably be replaced by j-boxes "large" with strain relieve)
