Latest post 05-29-2010 7:30 AM by StUrrock. 12 replies.
Page 1 of 1 (13 items)
  • 04-17-2010 2:59 PM
    Another question about Ps3-BS3
    in order to use the beo4 on my Ps3 i need to plug a simple usb-ir pen ,whatever brand,or must be sony brand?
    I just bought the 120gb slim ps3 to replace my DVD1
    Regards, Andrea
    One more thing....i would like to use playtv(sony) as DTV on ps3,anybody use it?Any suggestion?Is it worthy...
  • 04-17-2010 3:07 PM In reply to
    Re: Another question about Ps3-BS3
    Any brand (don't think sony make one).  However, this won't let you power on the PS3.
    If you want a near perfect solution, check out www.re-bl.com.  A PUC exists for it, too.
  • 04-17-2010 4:46 PM In reply to
    • TWG
    • Top 75 Contributor
    • Joined on 04-17-2007
    • Germany
    • Posts 950
    • Gold Member
    csmager:
    Yep, go for the RE-BL adapter, I have it, too and I'm VERY happy with it!
    Check out the review:
    http://forum.beoworld.org/forums/t/31328.aspx
  • 04-22-2010 2:53 PM In reply to
    thanks for reply,
    btw i read this in the site "Setting up a Beo4 remote RE·BL X accepts 38kHz IR signals, and can therefore be controlled with a Beo4 using the PUC output found on most modern B&O TVs. Make sure the STB list on the TV has been updated, then choose “Sony PS3 RE-BL” in the list (if “Sony PS3 RE-BL” is not in the STB list, the TV must be updated by a certified B&O technician)."
    i just updated the firmware but i don't have that sony ps3 re-bl....but i have Playstation 3 on the stb!will it works?
    Honestly if the functions are the same of 10€ usb-ir adapter i think i will go for that...
  • 04-23-2010 2:45 AM In reply to
    • mbee
    • Top 50 Contributor
    • Joined on 04-18-2007
    • Paris, France
    • Posts 1,133
    It's the same, with Re-BL, there is just one more thing : you can power up the PS3. With the $10 adapter, you can do everything else, but have to power the ps3 via its button or a pad.
  • 05-27-2010 9:35 AM In reply to
    sorry, need help..
    i can't get out of it,i plugged the ir blaster on AV2(i use dvd button to recall my PS3,on AV2 connection i selected "sony playstation 3" under set top box, i paired re-bl with Ps3,but when i press buttons on my beo4,nothing happens!!only my ir blaster flash,nothing else....
    where i'm wrong??????i followed step by step this guide http://www.wbe.se/files/re-blquickstart-bangolufsen.pdf
  • 05-27-2010 10:10 AM In reply to
    Unfortunately, as the intructions say, you need the Sony PS3-REBL PUC.
    If you don't have this, you can try a Sony DVD player if you have one listed.  Else it's off to ring the dealer to get it added...
  • 05-27-2010 10:15 AM In reply to
    so mbee wasn't right!??
    My "Sony Playstation 3" on the set top box list,is completely useless for my beo4..... [:'(]
    uff, i need to recall assistence
  • 05-27-2010 10:58 AM In reply to
    • mbee
    • Paris, France
    • Posts 1,133
    There seems to be a misunderstanding here :
    I said that Re-BL does exactly the same as any $10 IR receiver for PS3, appart than with RE-BL, you can power on the PS3. (Your last question was if a $10 adapter was sufficient, not if RE-BL works with Sony PS3 PUC item!!) Wink
    If you want to use an USB adapter such as NYKO (which doesn't power up the PS3), you have to choose Sony PS3 on the PUC list.
    If you use RE-BL, you need the Sony PS3 RE-BL on your PUC list. It's not there? You just need to ask your dealer to add that specific item on the list.
    Note that upgrading your BS3 software doesn't update the PUC List : this list contains a limited number of devices (not all devices, probably for ease of use), which have to be asked to your dealer.
  • 05-27-2010 11:02 AM In reply to
    my fault mbee,i misunderstood,most important is that i've found what is the problem and the solutions ;)!
    thanks
  • 05-28-2010 6:51 AM In reply to
    • StUrrock
    • Top 500 Contributor
    • Joined on 02-04-2008
    • Cambridgeshire
    • Posts 219
    For all you PS3 fans who would like it to talk to your mac, have you tried this?
    http://www.nullriver.com/products/medialink
  • 05-29-2010 3:59 AM In reply to
    • Toubro
    • Top 200 Contributor
    • Joined on 04-16-2007
    • Copenhagen, Denmark
    • Posts 263
    StUrrock:
    I've tried the demo version and it's okay, but it only streams formats that the PS3 recognizes. Take a look at http://ps3mediaserver.blogspot.com/ It's free and can convert files that are unplayable by the PS3 on the fly.
  • 05-29-2010 7:30 AM In reply to
    • StUrrock
    • Cambridgeshire
    • Posts 219
    Thanks Toubro
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
