Phil,
I prefer not to use a BeoLink Active for that purpose. I have a link room with a non B&O tv and a BeoLink Active. This room conflicts with audio usage of other link rooms at the same time. I want to get the same behavior as from a B&O tv in a link room. With the B&O tv in the bedroom I can use all main-room video sources (mono sound through RF) without interfering with the audio usage in the dinning room.
When using a BeoLink Active, it registers as an "audio device" and routes the sound over masterlink audio. In that case, the dinning room will get the tv sound.
I know that it is possible to connect a lintronic box to a BeoLink Video to receive ir commands and send the commands to masterlink. I thought it should be possible to do it with a B&O IR eye too.
msinn
