Hello, new to Beoworld and new owner to an old Beomaster 3000 type 2402!
Before I bought it I was told that there was scratch and bad noise from the switches so the first thing was to clean all switches as been told in this forum. After that and a gently cleaning of in-/outside I ended polish the teakcabinet. I tested it with “testspeakers” before I went on with my small Beovox. Nearly all scratches were gone and it sounds pretty good (compare to my Beomaster 900 I maybe taste some hifi… )
After about 6 hours happy CD-playing I began to hear some “hum” from the receiver, before that it was quiet. I have located it to the transformer and you can feel a light vibration. There is no distorsion or hum from the speakers, only from the receiver. If I continue to play, can it be worse or can I damage some other components. Thoughts about the "hum"?
It looks that the unit has been opened before but all components seems to be old and “original”. I also think that the receiver has not been used for a while, maybe stored in a garage because there were lots of dead flies inside…
With no right antenna connector, I only have tested with loose wires. There is difficult to get a good signal and the stereo lamp has not been lightning. Can it be something wrong with the FM-unit? The 3-pin connector, can it be bought?
Hopefully there are enthusiasts and experts here who can get me some advice?
Regards
Pelle, Sweden
