Hi ... I have been checking the previous thread you had with other problems ...
--> http://forum.beoworld.org/forums/p/32867/267243.aspx#267243
Can I ask you to check if:
1) you have the BV8 set to transmit on the RF
and
2) the BV6 set to the channel the BV8 is using
This is my set-up and how I access it:
[DTV]
[MENU]
select 4 (SETUP)
select OPTIONS
select ACTIVE ANTENNA
select ON
What I cant remember (yet) is how to set the frequency
But make sure your RF is on
Then select a channel on TV or DTV
and then try tuning your BV6 to see if it picks up that signal
First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
