I know there is a thread for this but I have a loose wire too... not that I am barking mad.
About half my CD's wont play now and when I connect this loose connection to the obvious point (ie where it is pointing) then none of the CD's will play. So I am not sure whether it should be connected to anywhere.
This request has been posted for some time but I have been very busy but now have time to sort this out.
I know that it is due to some components drying up and that they are easily replaced with the right tools and skill.
I also have been given a couple of names... Keith Saunders and Dillen, whether this is right or wrong I don't know.
Anyhow have a look at my blog for this, the link is below and email me if you can help.
http://robinknighton-radnorhills.blogspot.com/
bartonfam5@gmail.com
Many thanks
Regards,
Rob Barton
Oh... and by the way, if you are looking for an affordable website or online shop then have a look at http://www.ker-chingmedia .com
