Latest post 05-26-2010 7:39 AM by Rob Barton. 8 replies.
Page 1 of 1 (9 items)
  • 04-13-2010 8:11 AM
    • Rob Barton
    • Not Ranked
    • Joined on 08-21-2009
    • Knighton, Wales, UK
    • Posts 6
    BEOCENTER 9000... CD's Stop Playing
    I know there is a thread for this but I have a loose wire too... not that I am barking mad.
    About half my CD's wont play now and when I connect this loose connection to the obvious point (ie where it is pointing) then none of the CD's will play. So I am not sure whether it should be connected to anywhere.
    This request has been posted for some time but I have been very busy but now have time to sort this out.
    I know that it is due to some components drying up and that they are easily replaced with the right tools and skill.
    I also have been given a couple of names... Keith Saunders and Dillen, whether this is right or wrong I don't know.
    Anyhow have a look at my blog for this, the link is below and email me if you can help.
    http://robinknighton-radnorhills.blogspot.com/
    bartonfam5@gmail.com
    Many thanks
    Regards,
    Rob Barton
    Oh... and by the way, if you are looking for an affordable website or online shop then have a look at   http://www.ker-chingmedia .com
  • 04-13-2010 2:40 PM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: BEOCENTER 9000... CD's Stop Playing
    What is a CD restorer ?
    Snake oil ?
    The flying resistor should connect to the twin-pad that also connects to the
    nearby light brown'ish SMD component (and a black SMD too).
    I suggest you replace the capacitors on that board. Note that at least one of the
    caps need to be of a specific brand and type to work correctly.
    A kit exists. Not a free repair as you ask for but probably the cheapest possible.
    Don't adjust anything !
    And...
    WD40 contains acid in some form and is good for losening rusted bolts in cars.
    It has no place in your livingroom - let alone inside your B&O stereo.
    It evaporates - but not completely. That is, it does not remove any dust and dirt,
    it merely shifts it about and only in rare cases won't it add to the mess.
    I suggest you keep it in the garage.
    The need for lubrication to any parts of the CD deck is practically zero.
  • 04-15-2010 10:11 AM In reply to
    • Rob Barton
    • Not Ranked
    • Posts 6
    Thanks for your input....
    A CD Restorer looks like a portable CD player only it takes a thin layer at a time to remove scraches.
    The dry joints I refer to with WD40 are solder joints
    I did not know there was a kit to puchase and I am in work now as a website designer so don't mind paying.
    Where are the kits for sale?
    Regards,
    Rob Barton
  • 04-19-2010 1:41 AM In reply to
    • Dillen
    • Posts 5,008
    You cannot repair cracked (or "dry") solder joints with WD40, you need to clean off the old solder
    and make a new joint using a proper soldering iron, electronic tools etc.
    These tools are also needed to replace the capacitors.
    If you don't have these tools (or the skills needed), I suggest you leave it to someone who does.
    The servo board is of a cheap production and quite sensitive, copper tracks are easily broken and
    the board itself won't stand too much heat or wrong handling.
    The capacitor kits are made by me.
  • 04-19-2010 4:01 PM In reply to
    • Craig
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Dillen:
    Snake oil ?
    Seen these before, usually in shops which sell second hand games for consoles etc. For want of a better description in skims the top layer of the disc to remove scratches etc.
    CraigSmile
  • 04-19-2010 4:31 PM In reply to
    • Dillen
    • Posts 5,008
    OK, sounds like a fair product then.
    I was afraid that it was some new magic CD edge paint or
    a magic stone to put on top of your CD player to avoid
    interference from outer space. Laughing
  • 04-20-2010 6:08 AM In reply to
    • Craig
    • Posts 4,855
    Dillen:
    They both sound like great products. Where can I order them from?LaughingLaughing
    CraigSmile
  • 04-20-2010 8:11 AM In reply to
    • Dillen
    • Posts 5,008
    Rob,
    It's a fairly cheap kit but does require electronic skills and tools.
    The fact that you don't mind paying is of course nice - but doesn't make the kit more expensive.  Laughing
    You have a PM, check your inbox.
    Craig,
    The same place you bought the two Eiffel Towers and those fancy chromed bananas to put in the glove compartment
    for counterweight in sharp turns.  Laughing
  • 05-26-2010 7:39 AM In reply to
    • Rob Barton
    • Not Ranked
    • Posts 6
    Sorry for the delay since I last contacted you all..
    One day I will get round to actually doing something with my CD Player.
    But to Start with I need to be told (again) how to get hold of your repair kit.
    Thanks for the tips on handling the board with care.
    So lets get the ball rolling I am realy missing the CD's in my collection that won't play.
    How much is a pair of Penta's these days?
    Cheers, Rob
    robert@ker-chingmedia.com
