        1st March February 2012
	    Latest post 04-13-2010 4:50 AM by timhanna . 18 replies.
								    |  04-11-2010 1:49 PM |  |
									                 timhannaJoined on 11-28-2007LondonPosts 602 |
										    Hi, I just got a BeoLab 2000 and it sounds like just the left side speakers are working, or at least they sound louder! I played CDs, Radio, TV etc via link. There is no out of sync sounds... Also the standby light turns into an amber looking colour, is this normal, or am I confusing it for green? please help. |  |
									                 DanielJoined on 04-17-2007Svinarp, SwedenPosts 1,284 |
										    Re: BeoLab 2000 Amber light?
										    No, it's not normal. I've never seen an amber light on mine, sounds like a signal for fault. Beovision LX5500, BeoCord V6000, BeoSound 9000, BeoLab 8000, BeoLab 3500, BeoLab 2000, BeoVox1, BeoCom 6000, Form1, LightControl 1 |  |
										    Maybe I misunderstood you. When BL2000 is activated the left red lamp turns into green. It's not darkgreen so maybe it's the normal coulor. I know some speakers shows an amber light when there is something wrong, so why not BL 2000 as well. The right lamp is only turned on (red) when [TIMER] is activated. Beovision LX5500, BeoCord V6000, BeoSound 9000, BeoLab 8000, BeoLab 3500, BeoLab 2000, BeoVox1, BeoCom 6000, Form1, LightControl 1 |  |
									                 ernieJoined on 10-28-2007Posts 114 |
										    Amber light means you've got a problem in your ML cable/plug... |  |
										    Hi All, Think it might sound more normal now after changing the ML port, but the colour is still not the bright green that im used to from the BV1 etc, is this normal? |  |
									                 DoubleUJoined on 05-09-2007Posts 866 |
										     timhanna:after changing the ML port
 In that case, you might want to check visually the pins of your ML port. The plug is not easy accessible to pull out or to get in, when it is/was hanging on the wall. Chances are one pin is bended, and doesn't make contact with your plug anymore.   |  |
										    I check and they look ok on the BeoLab 2000.  Does anyone know if the Light is supposed to go amber if there is a problem with it, because I have read all the manuals, courtesy of beoworld and it doesn't mention anything about it going ambery... Is the light supposed to be as green as the BeoVision 1? |  |
										    I doesn't have a BV1, but I think the green light on my BV is greener compared to BL2000. Is on work now so can´t check until tonight. Beovision LX5500, BeoCord V6000, BeoSound 9000, BeoLab 8000, BeoLab 3500, BeoLab 2000, BeoVox1, BeoCom 6000, Form1, LightControl 1 |  |
									                 ViennaJoined on 08-15-2008make an educated guessPosts 712 |
										      There are two reasons for the ON/STANDBY LED to be illuminated in "amber / orange / dark yellow":
 1 - Unit is faulty - warning message - LED is OK  2 - Unit is working fine - but LED ITSELF is faulty |  |
										    Thanks for the inputs guys... I guess I will have to return the item after all...  Shame. |  |
										    I did notice something else strange though.. my BV1 in the bedroom seems to sound louder on the left speaker than on the right when I play linked music, I havent tried hearing out for it whilst watching TV... The LED is bright green though. The thing that they all have in common is a bosscom 8 port ML junction... could this cause trouble? Yesterday I tried 2 bosscom ML, what I noticed is that for the BV1 to work, I had to have all cables connected on one side of the plugs. There are 4 plugs on either side of the box.... if one plug is on the left and 3 on the right, the TV doesnt seem to be linked... Could this all be signs of a dodgy ML box and not actually the speaker? |  |
									                 tournedosJoined on 12-08-2007FinlandPosts 5,808 |
										    Have you gotten a second opinion on the colour? These bicolour LEDs can sometimes be a little hard to work out if you have a slight form of colour blindness you might not even know about. I know I have problems with them! |  |
										    hehe. I know what you mean and trust me I was going paranoid! Compared to the BV1 it definitely doesn't look AS green as it... |  |
									                 stefan
 Joined on 04-16-2007200 miles from StruerPosts 1,733 |
										     timhanna:
 Your Masterlink wiring seems to be faulty. The orange (orange/white) and red (red/white) in addition to the ground wires are for audio L-R. It`s a three wire balanced signal per channel. If a wire is not properly connected, this cannel will sound "thinner" and not as loud as the other channel. As you have the same problem on your Link TV, I think this is the reason. For the Stdby light (green - red) I assume you bought the BL2000 second life. Some people (like me) "darken" the small glass in front of the IR unit to reduce IR reception. I have done that to avoid the double command problem in the mainroom. Sometimes my BV7 and my BL2000 received the Beo4 commands. Now it works fine, but the green light seems to be darker than before. Maybe it`s the same with yours? Stefan |  |
										    Thanks Stefan, Ill check the cables when I get home... but I got both cables from LifeStyle and from Sounds Heavenly...  Ill try and connect the BeoLab 2000 directly to the ouverture and see what happens. Yes, you are correct, I got the BeoLab 2000 second hand... which is always a worry... |  |
										     Daniel:
 Home now (but still working, whatever happened to the economic crise?). They are pretty much the same colour: green, almost yellow. Beovision LX5500, BeoCord V6000, BeoSound 9000, BeoLab 8000, BeoLab 3500, BeoLab 2000, BeoVox1, BeoCom 6000, Form1, LightControl 1 |  |
										    Thank you for all your help Daniel, I just ordered a B&O ML distributor now and will return the speaker back... Ill look for another one... :S |  |
										    Have you tried its function without connecting it to the ML system? In that way you can test if the unit is faulty or the ML cable/plug...   |  |
										    Hi there, I did, but it just stays RED, because anything you press, requires an ML Source... :'( On a more positive note, I have finally implemented a mac mini/boxee solution and its AMAZING!! |  |
						     Page 1 of 1 (19 items)  |
