Latest post 04-13-2010 4:29 PM by Vox_T. 8 replies.
Page 1 of 1 (9 items)
  • 04-10-2010 3:37 PM
    • Vox_T
    • Not Ranked
    • Joined on 04-10-2010
    • Posts 14
    Beogram 2400 arm not returning at end of record
    The arm sets down at the proper place on the record but does not lift and return unless I lift it past the end of the record. Sounds like an adjustment needs to be made. Any ideas? Thanks!
  • 04-10-2010 6:05 PM In reply to
    • Vox_T
    • Not Ranked
    • Posts 14
    Re: Beogram 2400 arm not returning at end of record
    Here is a picture of my Beogram.
  • 04-11-2010 11:32 AM In reply to
    • Vox_T
    • Not Ranked
    • Posts 14
    Help, anyone?
  • 04-11-2010 12:41 PM In reply to
    There isn't actually an adjustment as such for this - I wonder in this case whether the mechanism needs cleaning. It is the lead out track that usually causes the arm to lift. Does it never lift?
  • 04-11-2010 1:19 PM In reply to
    • Vox_T
    • Not Ranked
    • Posts 14
    It lifts on 50% of my albums. Which mechanism needs cleaning? The big plastic wheel?
  • 04-13-2010 3:45 PM In reply to
    Had a chat to a friend about this - it is the silicon damping for the arm drop. The trick is to take off the platter, secure the arm, turn the turn table upside down and take the bottom off. There is a brass pin which is part of the damping mechanism. You need to dribble a little WD40 down the brass pin - it should get into the silicon and thins it a bit.
  • 04-13-2010 3:46 PM In reply to
    Which country are you in? I don't think this type of 2400 was sold in the UK.
  • 04-13-2010 4:16 PM In reply to
    Similar thread here!
  • 04-13-2010 4:29 PM In reply to
    • Vox_T
    • Not Ranked
    • Posts 14
    USA.
