Had a chat to a friend about this - it is the silicon damping for the arm drop. The trick is to take off the platter, secure the arm, turn the turn table upside down and take the bottom off. There is a brass pin which is part of the damping mechanism. You need to dribble a little WD40 down the brass pin - it should get into the silicon and thins it a bit.
