1st March February 2012
Latest post 04-06-2010 7:02 PM by Beroli. 10 replies.
04-02-2010 1:03 PM
madslp
- Joined on 09-06-2009
- Posts 58
I'm running 3.57 on my old xp laptop, beacuse my new Win7 64bit dosent support beo5 remote and software..
Can 3.59 solve my problems?
Best Regards
Mads
BS 3500, BL 8000, BL 6000, BL 4000ice, BL2000, BL3, BL2, CX100, CX50, Cona, MCL/ML, BPC2, MX7000, MX4000, Beotime, Beo5, Beo4, Beo4cinema, Beo1, Beo1000, A8.
Beroli
- Joined on 02-05-2009
- Posts 38
Re: New functions in 3.59??
Hello Mads,
short answer. No! Windows 7 does not support the 3.59-Version of Beo5 CT. It is the same Driver-Problem like in 3.57. The Beo5 will be not detected in 64bit-Versions.
Have a nice Easter-Weekend
Beroli
madslp
- Posts 58
Hey and thank you alot...
Okay, but i still works on my old laptop.. What are the new functions in 3.59?
Good Easter to you.
Mads L P
hansb
- Joined on 12-15-2009
- Posts 11
I had the same problem with Windows 7 but didn't want to run it on an older XP machine. I got around it by downloading installing the Windows XP Mode for Windows 7. Basically, it creates a virtual XP machine within your machine. If the Virtual XP 'machine' crashes, it has no effect on your Windows 7 operations.
The config software now runs flawlessy on my Window 7 64 bit machine.
Hans
Tillquist
- Joined on 05-26-2007
- Denmark
- Posts 211
Doses some one now where to download 3.59 ?
My Bang & Olufsen....
- BeoCenter 2 DAB/DVD mk.II
- BeoVision 7-40 DVD mk.III
- BeoLab Penta mk.III
- BeoLab 4000 icepower
- BeoLab 4000
- BeoLab 3500
- Beo 5
- Beo 4 mk.I & mk.III
- Beocom 6000
- A8 Earphones
Dapper
- Joined on 03-18-2010
- Posts 26
Hi MADSLP,
I too run with Windows 7 64-bit and found that the BEO5 configuration program doesn't run under W7 64-bit.
However, I did find a workaround. If you download the the WINXP mode for Windows 7 ( link http://www.microsoft.com/windows/virtual-pc/download.aspx ) and install it, you will be able to run the program under W7. Do not forget , once the XP mode machine has started, to attach the BEO5 to the virtual machine. It works well on my setup.
Good luck!
Peter.
Dapper
- Posts 26
O well, just saw the update from Hans with the same message. Sorry for the double post.
Peter.
madslp
- Posts 58
Thaks HansB, i worked also fine for me..
hansb
- Posts 11
Anytime...hey, where did you get 3.59? I haven't seen it available anywhere yet. Let me know.
Hans
madslp
- Posts 58
I haven't the 3.59, but I will also like too. You let me know..
Beroli
- Posts 38
Hi hansb, hi madslp,
Please understand that I do not want to distribute software. Any distribution of the Beo5 CT 3.59 in this forum, would violate the B&O copyrights . So, It´s to dangerous sued by B&O. Please ask your favorite B&O dealer or wait a little bit. Some people are not so anxious like me and maybe they will upload CT 3.59 in www.
So please, don´t be angry with me.
Beroli
PS: The Question was the support in Win7 64 bit and this problem is still not solved in Beo5 CT. I use a virtual XP under MacOS and it works fine.
Page 1 of 1 (11 items)
