Hi!
Ive heard about a product, not B&O, but cant remember the productname. This thing can be connected to any B&O soundsystem, and via internetcable receive internetradio, and be controlled via Beo4.
Does anyone know this product?
Beoport will do this, and can be controlled via Beo4. Not sure of a non B&O device.
Craig
According to the Lintronic website, the Beo4 uses code set 703: shared by many Panasonic devices but not much else.
Are you thinking of the Roku or Pinnacle Soundbridge? I use one at it provides very good results, but needs its own remote controller unless you opt for a Lintronic based linking solution. I'm not sure whether there is much difference between a Soundbridge left on line or put into standby. Listening mostly to one station you could leave it running and just switch the connected Beomaster on and off with the Beo4.
Graham
I used to be indecisive, now I'm not so sure. [W C Fields]
What about this one?
http://shop.oneremote.dk/catalog/product_info.php?products_id=3060&language=en
Sverre
