To reset the Phonebook, Caller ID, Redial List and registered handsets, you have to first reset the base, then the registered handsets one after another:
Press the dot (shift function) placed between the A and V keys followed by 70008 and then OK (in the middle of the wheel) to reset the base.
Press the dot followed by 70009 and OK to reset each single handset.
Hope this helps.
