hello
I have a CDM12 IND pickup that read cd but when I power on the unit it doesn't find the disc. If I try and try it starts to read and reads all the disc I insert without problem.
On the net I found that the cdm12 ind could be replaced by the CD-Pro2LF
http://www.akustik-perfekt.homepage.t-online.de/the-audio-collection/english/cdplayer/buildingblocks/cdm12_to_cd-pro2.html
but in this site there is a note
http://www.diy-high-end.com/
Does someone tried to replace the CDM12 ind?
Thanks in advance
PS: the unit is a Century
Eugenio
The CD-PRO2LF is downward pin compatible
but not suited as replacement for older systems with clock insertion.
The CD-PRO2LF
can’t be used for B&O repairs.
